diyAudio Sponsor
Old 6th February 2010, 06:14 PM   #31
astouffer's Avatar
Originally Posted by regal View Post
FYI: I've been told by many that the LM317 series regulators aren't quiet enough for DHT supplies, you may be dissapointed.
The LM317 will be fine, especially with the bypass cap across the resistor from adj to ground. There's plenty of people who run DHT tubes from AC supplies without issue. Tubes that are sensitive to filament hum tend to be very high mu transmitting tubes like the 811A. I run 845s on 10vac filaments with a hum balance pot and its only noticeable with your head against the speaker.
Old 30th December 2010, 02:41 AM   #32
tomchr is offline tomchr  United States
tomchr's Avatar
SGregory: How goes the project? Did you actually order those Electra-Print transformers? What do you think of them? Which load impedance and bias point did you end up with for the 300B?
I'm considering upgrading to the Electra-Print transformers for my design, hence my question.
~Tom
Old 30th December 2010, 03:24 AM   #33
Tubie Noobie
Tom,
The project is on hold for the moment. I need to see if I can make a 6c45pi stable outside of its cardboard box first. Have been working on my analog source recently and am about to start a new thread on a Gyrator loaded 12b4a if it sounds as good as it measures. (Not always the case as you know. Am getting 0.01% THD with a -130dB noise floor.)
I have ordered several Electra-Print PT's, Chokes, and OPT's and have never been dissappointed. They are not fancy but are solid and have excellent sound. If you are refereing to the interstage xfmr I am comfortable with Jack's skills and would trust them as well. They are not too expensive unless you go exotic.
Living Life Doing the Waltz in 4/4 meter.
Old 30th December 2010, 04:37 AM   #34
tomchr's Avatar
I'm currently using Edcor transformers (CXSE25-8-5K) but am not terribly thrilled with them. For low powers, they're good bang for the buck. But the 300B should be capable of delivering over 10 W with 3k load when run close to the max plate dissipation. Some playing with the plate curves and paging around in RDH4 suggests that 10.8 W @ 3.5 % THD should be possible. Of course, that's with an ideal output transformer.
~Tom
Old 30th December 2010, 04:46 AM   #35
tomchr's Avatar
0.01 % THD, -130 dBV is nice by the way. Very nice!!
My 6J5 driver runs 0.05 % THD.
~Tom
Comment on my DIY Sub Design htgeek Subwoofers 22 8th April 2005 05:26 AM
Please comment this design promise Solid State 0 20th January 2005 05:25 AM
Can anyone comment on the tektron 300b/2a3? swak Tubes / Valves 0 5th August 2003 07:50 AM
First speaker design - please comment sobazz Multi-Way 19 19th May 2003 10:23 AM
comment on this design, please. JAZZ2250 Tubes / Valves 6 24th November 2002 10:45 PM
Page generated in 0.11393 seconds (60.39% PHP - 39.61% MySQL) with 11 queries
