Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 4th November 2009, 01:13 AM   #1
i45one is offline i45one
Default 100uF Motor Run Caps
I am starting to source parts for my 1st tube amp project. I am looking to construct Porkchop's KT88 se circuit.
Does anyone know where I can find a suitable 100uF motor run cap? It seems as though no one really carries anything that large in the voltage required. Angela carries 50uF, but I would rather not have to parallel two caps if I can help it.
Are there any other alternatives?
Thanks!
Old 4th November 2009, 02:16 AM   #2
88man is offline 88man
I haven't found any 100uF motor run caps myself, as the largest one I've seen is 60uF. I am building Abdellah/Alexg/Porkchop's SE KT88 too - I am paralleling (2) 50uF caps for my project. Great selection and prices at Alliedelectronics.com.
Old 4th November 2009, 03:39 AM   #3
pjanda1 is offline pjanda1
pjanda1's Avatar
Ebay often has cheap big 'uns. There was one seller in particular, but I can't remember who. These guys have some large fellas as well. Don't forget that you can multiple that AC voltage by 1.4 or so for your purposes.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 4th November 2009, 04:33 AM   #4
rdf is offline rdf
rdf's Avatar
Some are still available on Ebay. Check out local electrical suppliers to the HVAC industry first.
"My loony bun is fine Benny Lava!"
Old 4th November 2009, 04:40 AM   #5
kevinkr is offline kevinkr
Contributing
kevinkr's Avatar
midori meadows on eBay used to carry 100uF motor runs, but ran out a while ago, and I have not checked to see whether or not they have restocked.
Edit: Link here to eBay profile: http://myworld.ebay.com/midorimeadowsllc/
Note that she currently is offering 80uF/500VAC motor runs by Eyuda for $13 each...
I've done business with her, and have recommended her as a source of motor runs to a number of friends over the last few years.
Kevin
www.kta-hifi.net
Old 4th November 2009, 04:44 AM   #6
tomtt's Avatar
Location: kansas city mo, and on occasion, ditches around the world ...
heating and cooling shops might have used ones.
Old 4th November 2009, 09:26 AM   #7
alexg is offline alexg
alexg's Avatar
I find that the ASC, Aerovox and the GE motor run capacitors sounds excellent on my PSUs.
I usually parallel a couple of 45 or 50uf, to get the capacitance that I need.
Old 4th November 2009, 12:39 PM   #8
Thanks for all the input! I look forward to working on this project. It's refreshing to know that there are great folks around willing to help as this is my first tube build. I'm sure I will have tons more questions before it is through.
Old 4th November 2009, 01:05 PM   #9
piero7 is offline piero7
piero7's Avatar
MKP caps: CLICK ME
Old 4th November 2009, 10:50 PM   #10
Geek is offline Geek
GlassFET
Geek's Avatar
Originally Posted by piero7 View Post
MKP caps: CLICK ME
I wonder if it's inductively wound though....
Cheers!
-= Gregg =-
"Ratings are for transistors...tubes have guidelines"
Hobby and communites - GeeK ZonE
Commercial site - classicvalve.ca
diyAudio Blog - GeeK's Bench
Thread Tools
Need a single ASC 100uF Motor RUN cap jmillerdoc Vendor's Bazaar 0 3rd November 2009 03:16 AM
Motor run caps. New, unused. 50uF and 100uF. nodiak Swap Meet 1 30th January 2009 12:30 AM
Still tring to find a couple 100uf motor runs audiobliss Tubes / Valves 16 12th August 2008 10:28 AM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 04:15 AM
FS - (4) 100uf Axon Caps Guiness Swap Meet 1 30th May 2008 06:35 PM
Page generated in 0.18364000 seconds (66.05% PHP - 33.95% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
