diyAudio Sponsor
Old 4th November 2009, 11:02 PM   #11
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
very small for MKP, even Chinese manufactured CBB60 or CBB61 are larger.
The 400uF/450V caps on offer by that seller are stated to be 50x110mm.
An Epcos MKP pulse cap of that size has 2.5 times the height and almost twice the diameter.
Old 5th November 2009, 01:16 AM   #12
Geek's Avatar
Good point Jacco.
Come to think of it, they look the same as those sold in a local hardware store as electrolytic "motor start" caps.
Hey, it's cheap enough... someone should snag one and cut it open
Cheers!
Old 5th November 2009, 01:44 AM   #13
DynacoDave's Avatar
You can also shop electric motor repair shops. I picked up a start cap for my dust collector for 6 bucks. They had about 1000 different values, voltages, and manufactures.
Old 5th November 2009, 02:04 AM   #14
kevinkr is online now kevinkr  United States
kevinkr's Avatar
Large motor runs are all somewhat inductive, but then so are most electrolytics.
These are probably ok, and at the price it is hard to imagine you could go wrong.
Odd that the seller who is based in Hong Kong listed them on eBay Italia.. Io penso di comprare qualche pezzi di questo condensatore.
www.kta-hifi.net
Old 5th November 2009, 02:15 AM   #15
Geek's Avatar
Run the auction number through ebay.com or ebay.ca or ebay.co.uk, Kevin, it's just a worldwide auction I think...
Cheers!
Old 5th November 2009, 12:57 PM   #16
piero7 is offline piero7  Italy
piero7's Avatar
I've payed the ICAR 90uF motor run here in italy 9 euro and they was 55x116 mm
Old 5th November 2009, 02:01 PM   #17
DynacoDave's Avatar
Don't forget motor run caps are ac.
Old 6th November 2009, 12:51 PM   #18
Face is offline Face  United States
Face's Avatar
Why would you use one of these opposed to a standard 100uf film cap?
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen
Old 6th November 2009, 01:10 PM   #19
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
experience and sanity are just two reasons I can think of in this moment
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 6th November 2009, 01:11 PM   #20
piero7's Avatar
huh? A polipropilene cap is a poliprpilene cap anyway
why to use these instead an electrolitic? Give a try, remove your electrolitics from your tube amp and give a chance to these motor run poli caps and hear your music as usually...
Need a single ASC 100uF Motor RUN cap jmillerdoc Vendor's Bazaar 0 3rd November 2009 03:16 AM
Motor run caps. New, unused. 50uF and 100uF. nodiak Swap Meet 1 30th January 2009 12:30 AM
Still tring to find a couple 100uf motor runs audiobliss Tubes / Valves 16 12th August 2008 10:28 AM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 04:15 AM
FS - (4) 100uf Axon Caps Guiness Swap Meet 1 30th May 2008 06:35 PM
Page generated in 0.10044 seconds (80.99% PHP - 19.01% MySQL) with 10 queries
