diyAudio Sponsor
Old 3rd November 2009, 05:36 PM   #1
Default Phono Stage
Hi Guys,
I have a valve phono stage and wish to use some Cinemag Input Transformers
My Phono stage is way too Noisey in Active mode so i need to use the MM input with the Cinemags.I still wish to use a MM every now and then too so i need to Switch between the two ,mm,mc .What is the best way to switch these unputs for the least signal loss.Whats the best Switch to buy please.
Regards James
Old 4th November 2009, 04:02 AM   #2
kevinkr's Avatar
Probably not what you want to hear, but at this signal levels there are very few switches that would be reliable for any length of time due to the extremely low signal levels.
I recommend you instead manually swap the connections as required unless you switch from one to the other type of cartridge on a regular basis in which case you need to look for a switch that is specifically designed to switch small signals and these can generally be recognized by the fact that their switched current rating is 10mA or less and the specification should state that.
Toggle switches generally do not have sufficient wiping force to keep the contacts in good conduction at these signal levels, but some rotary types from ITT Shallcross or Grayhill will do the job, but are expensive.
www.kta-hifi.net
Old 4th November 2009, 04:34 AM   #3
Geek's Avatar
I've used CK silver plated rotaries (like Digikey CKC7004-ND ) successfully for line selectors for a while now with great success. Weather they'll live long enough under those low signal levels is anyone's guess.
Cheers!
Old 4th November 2009, 04:48 AM   #4
Send a message via AIM to DigitalJunkie
What about mercury wetted relays? You'd want to supply the coils on them with a nice clean DC voltage though,to reduce possible hum pickup.
Old 4th November 2009, 11:13 AM   #5
Ok So a switch isn't a very good idea.Trouble is there is only one input on the board for mm .Could i conect both the transformers and a separate mm Input to this conection at the same time Via separate Phono inputs.Would this cause a problem if say im using mm would the Transformers be seen in the circuit path.....
Old 8th November 2009, 11:46 PM   #6
kevinkr's Avatar
No that won't work, the signal generated by one cartridge would attempt to drive the other and vice-versa, levels would be substantially reduced by the loading, and this would probably result in particularly poor performance with the MM cartridge, but probably both.
I would use a reed relay specifically designed for switching extremely low amplitude and current levels whether or not mercury wetted. Note that mercury wetted relays generally have specific required mounting orientations as well. Coil power must be very clean dc, any ripple present in the coil will be both electrostatically and magnetically coupled into the signal path, and at these signal levels it won't take many uV of induced noise to create a problem.
www.kta-hifi.net
Old 9th November 2009, 01:48 AM   #7
James,
The high quality reed relays needed to switch at these MINISCULE signal levels are costly and the CLEAN coil power supply needed will be expensive too.
It's quite likely you will do better in acquiring a 2nd phono preamp and connecting it to a set of line level I/Ps.
Eli D.
Old 9th November 2009, 11:26 AM   #8
Ok thanks for your help guys.I,m not going to fit the Cine-mags inside my phono stage,seems to be too much trouble.I will carry on using it off board.Then it will be esier to swap back to MM.I just wanted to eliminate the unnessesary cables etc...
Thanks again James
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Phono Stage... ncdrawl Analog Line Level 1 5th November 2008 10:14 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
PS for phono stage trianglezerius Power Supplies 0 20th March 2007 12:14 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.10043 seconds (82.00% PHP - 18.00% MySQL) with 10 queries
