| diyAudio Sponsor | ||
Hello, to all TV tube fans. An SE amp built with all tv tubes.
#2 |
' like it
True pentode CF and bootstraped driver ![]() You should patent that Yves. |
#3 | |
I did find and offer another idea. You can easily get a negative supply rail from the top transformer with 2 more diodes and a cap. Then hang a solid state CCS (set at your desired operating current) between the negative rail and the output tubes cathode. Careful bias adjustment can yield zero current through the OPT allowing the use of non gapped OPT's, even mains toroids. The OPT primary impedance is low, like 600 ohms, so mains toroids work well. I found that the really big sweep tubes like the 6LW6 work best, but a high Gm triode like the 6336A isn't bad either. You can also omit the bias circuitry and ground the grid resistor. Then a gapped OPT or parafeed cap is needed.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Many Thanks for all inputs!
here's what it looks. |
| PC Cooling Fans for Tube Amps | Dominguez | Tubes / Valves | 4 | 19th August 2007 01:06 AM |
| Good News For EI Tube Fans | Trout | Tubes / Valves | 20 | 13th January 2007 02:55 PM |
| amp fans | sriegel | Pass Labs | 4 | 5th January 2002 11:10 PM |
| Page generated in 0.09862 seconds (59.89% PHP - 40.11% MySQL) with 11 queries |
