diyAudio Sponsor
Old 2nd November 2009, 10:43 AM   #1
Default Yaqin MC-10L Heater Voltage
Hello all, first post. According to a previous thread on this site:
Yaqin mc10L
"Best to check the heater volts if you can, two yellow twisted wires around V2 on the pre-amp board at the top edge of board. This of course is AC volts and expected to be approximately 6.3V."
Just replaced all EL34 with matched quad set after V3 fizzled out two weeks ago and I set the bias to .35vdc. Yesterday the stereo started sounding garbled when I turned the volume up. So I shut it down and removed the cover. Checked my bias voltages and they were all about half of what they should be. Turned off the stereo set up my test leads to check another voltage turned stereo on and it sounds good and voltages where they should be then once I turn it up it gets garbled again. Checked the voltage on one of the heater wires (yellow twisted pair labeled heater supply in aforementioned thread) and I get 3.2vac to ground.
Am I measuring this correctly? I shouldn't measure the voltage drop between the twisted pair to get the 6.3v?
Old 2nd November 2009, 01:00 PM   #2
piero7 is offline piero7  Italy
piero7's Avatar
No. Test points are pin 2 and 7 of EL34.
Old 2nd November 2009, 01:19 PM   #3
tyu is offline tyu  United States
Default All Heaters
I did mine, came out at 6.5 v so only just over, near enough for me,
I say Not for Good tone!
An yes you have 3.2 on EAch wire to ground, 6.4 i have been doing work on High Heaters an Sweet tone,an have found lower is better for Better tone, An the maines change from day to night, at night the heaters can go to 6.9-7 sucks the life out of the sound, i am Working on a way to lower, a EZE way, There is a Big diff. in high too low, I think tube Heater Have, What I call Heater Headroom, High an the Xfourmer run Hoter,lower cooler. Run the input tube any higher than 6.3 an sound is glassy an hard,an when the maines change you will have 6.5-7, Amps preamps well sound Good sometime an Bad at others, i here this all the time.After All the one thing all the Tubes have Amp or Preamp is one Heater!
It got to be Right or all is lost.
Old 2nd November 2009, 05:55 PM   #4
Thanks for the answers guys.
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
heater voltage Jaap Tubes / Valves 3 18th November 2008 11:39 PM
Too low heater voltage? jkeny Tubes / Valves 6 26th August 2008 12:08 AM
DHT heater voltage zobsky Tubes / Valves 23 9th September 2006 03:55 PM
heater voltage: why ac, and not dc? alex278 Tubes / Valves 18 7th October 2005 12:21 PM
Page generated in 0.09015 seconds (72.69% PHP - 27.31% MySQL) with 10 queries
