| diyAudio Sponsor | ||
I plan to build a push pull amp with 807 and 6CB6 tubes with local feedback (see picture, from Glass Audio).
As I have some 2SK2700 lying around I wonder if it could be useful to add the powerdrive concept to this design ? |
#2 |
I've thought of adding a power drive or equivalent circuit to my 1624 local feedback amplifier to allow A2 operation. It should work as long as the input capacitance of the buffer is kept very low. I'm going to give it a shot using the amplifier version of the self bias CCS circuit used as a follower.
#3 | |
#4 |
You could always use a triode/pentode combo and use the triode as a follower. This would give you some AB2 capability, just not in full-tilt "George" style...
This is what I'm doing for my "Kingfisher P-P amp, and it still seems sufficient to drive the snot out of the 7591As. |
#5 | |
Experts, would this choice be suitable on this place ? |
#6 |
You may find some inspiration here:
6L6 Push Pull Should go with 807 as well. However, I was unable to apply local NFB without experiencing hi frequency instability issues, perhaps too capacitive FB resistors ? ? Could be a good idea to use multiple resistor in serie because they have very large voltage accross them . . . Yves. |
| Cascode with local feedback | croccodillo | Tubes / Valves | 8 | 19th July 2007 03:30 PM |
| How to accomplish local feedback in pp amp ? | Jaap | Tubes / Valves | 11 | 7th December 2006 05:04 PM |
| a question about local feedback | hacknet | Tubes / Valves | 8 | 16th August 2005 06:42 AM |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Page generated in 0.11295 seconds (62.10% PHP - 37.90% MySQL) with 11 queries |
