simple hybrid idea
simple hybrid idea
Old 21st May 2003, 02:47 PM   #1
nobody special is offline nobody special  United States
nobody special's Avatar
Default simple hybrid idea
I have an idea to use a differential pair of P-channel MOSFETs to bias and drive a pair of push-pull 6L6's running class A. I was wondering if anyone had seen this done anywhere. Think it will work? Think it would sound ok?
Steve
Steve
Old 21st May 2003, 02:57 PM   #2
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default The hibrid amp...
Think it will work?
Yes...me too!!
but the capacitor C1 must be connected in parallel with zener and not as in your schematic...as if it is connected as in the schematic you will ended with hum at the output!
I hope so!!
cheers
Jorge
Old 21st May 2003, 03:20 PM   #3
Yes, you think it will work, or yes, you had the same idea?
I don't understand why the capacitor where its at would be a problem. It is bypassing the current source mosfet's gate to ground. Maybe I should add another cap across the zener?
Thanks for the reply... there dosen't seem to be a lot of interest.
Steve
Steve
Old 21st May 2003, 03:35 PM   #4
Tube_Dude's Avatar
Default what's is bypassing what...
Yes but the source of the Q3 mosfet is referenced to the + 40volts rail...so the bypassing capacitor must be connected to the same rail for the mosfet doesn't "see" the hum voltage...and don't amplifie it
regards
Jorge
Old 21st May 2003, 03:38 PM   #5
Thanks... I see it now.
Steve
Steve
Old 21st May 2003, 04:01 PM   #6
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
As shown, you are DC coupled to the 6L6, which is nice. But you have no way of knowing whether your anode currents are out of balance and causing transformer core distortion, or of correcting imbalance. If you use separate 1R cathode resistors, you can detect imbalance, and you could add a servo feedback loop for correction, or add a manual tweak.
What advantage do you expect to gain from your proposed circuit over traditional glass driver circuitry?
Usually, hybrids go the other way, with glass to drive MOSFETs in a desperate effort to get rid of the output transformer.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 21st May 2003, 04:14 PM   #7
good idea... I was planning on adding a balance pot on the differential current source to give a little bit of an adjustment for balance. I think when I simulated it before, I used a 100 ohm with the wiper attached to the current source and the legs attached to each mosfet. This seemed to correct for DC imbalances, but AC is another problem. Any ideas?
Well, I guess the appeal is 1 gain stage in the front end with a fairly low output impedance. If I could find a way to balance it, I could drive multiple pairs of tubes with a lower impedance output transformer for more power without an additional driver circuit. 2 gain stages total- short signal path. Also, no caps in the signal path (not that it really matters, but it's kind of cool
Yeah, I've looked into doing that, but the circuit gets really complex when you have to drive the mosfet gate capacitance (white cathode follower or something similar)... I don't really see the point. If you have the right speakers, transformer coupling isn't necessarily that bad of a thing.
Steve
Old 21st May 2003, 04:26 PM   #8
ok... version 2 with the good suggestions above included.
-added individual anode resistors to check for balancing.
-added bias balance pot
-corrected misplaced zener filter cap
Steve
Old 21st May 2003, 04:27 PM   #9
EC8010's Avatar
Yes, the 100R source resistor will do the DC trick.
Do you know how much gm you are expecting, and thus how much gain? AC balance might not be a problem...
I wonder what the input capacitance of your gain stage looks like?
Most people object slightly to output transformer defects, and a lot to how much they have to pay for them. That seems to be the main incentive for MOSFET output stages. As you say, the large, and changing input capacitance is a pain.
Old 21st May 2003, 04:28 PM   #10
oops... here's the image
Steve
simple hybrid ideaHide this!Advertise here!
simple, hybrid Class D/G/H idea earthtonesaudio Class D 0 29th April 2009 05:48 PM
One more hybrid idea sajti Tubes / Valves 6 26th January 2009 11:58 AM
Hybrid OTL Circlotron idea revintage Tubes / Valves 85 3rd September 2008 12:06 AM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
