Old 21st May 2003, 04:32 PM   #11
nobody special's Avatar
Do you know how much gm you are expecting, and thus how much gain? AC balance might not be a problem...
Honestly, no. In my simulation of it I am able to drive the circuit above with 1V p-p and get full output. The output stage is basically taken straight from the RCA databook.
I could always match the differential mosfets and used matched output tubes... maybe then it would be alright?
Steve
Old 21st May 2003, 04:41 PM   #12
Tube_Dude's Avatar
Default The input that needs current...
I wonder what the input capacitance of your gain stage looks like?
Yes the input capacitance will be great...the gate source capacitance of the mosfet +the Miller capacitance ( the gate drain capacitance X the gain of the stage)...it will need some driving current in the high frequencys...
Mosfets are not my choice for input devices...
cheers
Jorge
Old 21st May 2003, 04:42 PM   #13
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
At maximum output, one output valve has its grid at 0V (a -17.5V swing) and the other at 35V (a +17.5V swing). Thus, there is 35Vpk-pk between the outputs of your driver stage. If there is 1Vpk-pk going in, then you have a gain of 35, and since Av = gmRL, that suggests gm = 35mA/V for the MOSFETs. It probably would be worth matching the MOSFETs, as they are notorious for device variation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 21st May 2003, 05:06 PM   #14
Tube_Dude's Avatar
Default The gain issue...
The gain can't be 35 because the degeneration source resistors...1k/100=10...and with the pot in series with the source resistors the gain will be even less...
Jorge
Old 21st May 2003, 05:08 PM   #15
Default Re: The input that needs current...
cheers
I don't see the problem, unless you are using a tube preamp with a fairly high output impedance. The P-channel differential pair is used in all the Pass Aleph amps with no problems, so...???
I understand that a lot of you tube guys like to use all tubes, so it could be an issue.
I will most likely be using it with a zen balanced line stage, which will drive it with no problems.
So, then (I ask myself) why use tubes? It's different. I haven't seen anybody doing it this way. Maybe there's a reason for that, haha. I'm going to give it a go anyway.
Thanks for all the help
Steve
Steve
Old 21st May 2003, 05:12 PM   #16
Default Re: The gain issue...
yeah, you're exactly right! I forgot to look at that when I added the balancing circuit.
Steve
Old 21st May 2003, 05:15 PM   #17
EC8010's Avatar
Good point. The simulation that gave the 1V sensitivity must have been run before the 100R source resistors were included. Still, the degeneration will reduce the Miller capacitance, which is handy.
Old 21st May 2003, 05:30 PM   #18
how about this...
it gives a bias voltage difference of +/- 3.68, and the sensitivity is reduced in half to 2Vp-p for 37V grid-grid (Vpeak) out.
a good compromise?
I'm not sure how much of a voltage difference the output stage would need to see to compensate for imbalance.
Steve
simple, hybrid Class D/G/H idea earthtonesaudio Class D 0 29th April 2009 05:48 PM
One more hybrid idea sajti Tubes / Valves 6 26th January 2009 11:58 AM
Hybrid OTL Circlotron idea revintage Tubes / Valves 85 3rd September 2008 12:06 AM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Page generated in 0.10643 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
