diyAudio Sponsor
Old 29th October 2009, 11:44 PM   #1
DougL is offline DougL  United States
Post Se Amp with Push Pull Transformer
I was reading "Designing Valve amplifiers" By Morgan Jones (Highly Recommended) and saw the page for cancellation using one valve, page 392.
I had some questions.
First, would each winding be 2*RP as a rule of thumb?
Would Av = 2 * mu/mu+1 ~ 1.8?
The circuit looks like it might work great with a toroid and maintain "perfect" balance. It would also work with something like the Lundahl LL1663, but not most classic push pull transformers.
I was thinking I could have a bit different amp.
Any thoughts are appreciated.
I was sketching concepts on my pad for this and thought I'd throw it out for comments.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 2nd November 2009, 06:37 PM   #2
Elias is offline Elias  Finland
Elias's Avatar
Hello,
got any picture of the concept?
- Elias
Reinventing the wheel !
Free wavelet software for audio analysis click here!
Old 2nd November 2009, 06:40 PM   #3
I will Sketch one up today.
Old 2nd November 2009, 07:31 PM   #4
45 is offline 45  Italy
45's Avatar
Doug
I think it could work well with triodes like the 6080/6AS7 that have a very low mu anyway....
Old 2nd November 2009, 07:42 PM   #5
dsavitsk's Avatar
It seems like such a nice concept. However, the problem is that the AC signals will exactly cancel each other out leaving you with almost exactly no output. That is, it is an error in the book.
Sims are from Slagle from a while back. Also, if you search AA for "chokertina" there was a discussion on this in 2003.
http://www.ecpaudio.com
Old 2nd November 2009, 08:17 PM   #6
45's Avatar
I was thinking about something like the Klimo Beltaine. Using the 6AS7, one triode is the amplier and the other for the DC balance only. Cathode follower config. if you like. Probably it doesn't work as well because the DC side has to be a current source.
I don't have the book by Morgan Jones .
Old 2nd November 2009, 09:30 PM   #7
Here is The Concept.
Push pull transformer with split, not center tap primary.
Standing current cancels. And since there is only 1 tube and Icathode and IPlate are equal until A2, the current ballance should be "perfect".
Morgan Jones said it was a problem to drive.
Doug
Old 2nd November 2009, 09:32 PM   #8
Really?
Thanks.
Sounded too good to be true.
Doug
Old 2nd November 2009, 11:07 PM   #9
It should work. The ac signals at the anode and cathode are opposite phase right?
Old 2nd November 2009, 11:20 PM   #10
smoking-amp's Avatar
"The ac signals at the anode and cathode are opposite phase right?"
Yes, but they are then connected to the same phase connections on the xfmr where they then cancel out.
Some related ideas here:
DC compensated SE output transformer
Ohms Law V = I R
6C33B-C push pull with output transformer vincent_brient Tubes / Valves 20 5th June 2009 06:49 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
Push-Pull converter with a gapped transformer ?? Joseph Hynes Power Supplies 30 25th December 2005 03:38 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
how to determine P1 from P2 of a Push-pull transformer? up4 Tubes / Valves 10 13th June 2005 10:54 PM
Page generated in 0.12356 seconds (68.37% PHP - 31.63% MySQL) with 11 queries
