diyAudio Sponsor
Old 28th October 2009, 03:26 PM   #1
Default ECL86/PCL86 Schematic
Any suggestion for a simple ECL/PLC86 SE Amp ?
Old 28th October 2009, 05:11 PM   #2
revintage's Avatar
This one will give you in the ballpark of 3W at 1% THD with low Zout.
Brgds
Lars
Old 29th October 2009, 03:06 PM   #3
Hi Lars,
Thnx seems nice, did you build it ?
Old 29th October 2009, 04:42 PM   #4
revintage's Avatar
It´s a SE version of whatis discussed here:
Spud, Schade, PP, Anti-triode ECL86
Brgds
Lars
Old 29th October 2009, 05:05 PM   #5
bigwill is offline bigwill  United Kingdom
revintage, out of curiosity, what kind of Zout do you get with that circuit?
Old 29th October 2009, 11:56 PM   #6
Ezequiel (kel)'s Avatar
ok SE ECL86 very simple
1.000.000 de Circuitos EletrĂ´nicos: Amplifier tube ECL86
sorry if wrong, my English is google translator
Old 30th October 2009, 08:47 AM   #7
revintage's Avatar
You get the same Zout as if the E(C)L86 had been triodestrapped.
Brgds
Lars
Old 30th October 2009, 06:12 PM   #8
Default simple PCL84 SE amp
Recently I built this one with two PCL84:
http://www.diyaudio.com/forums/attac...4&d=1152603590
It sounds nice and it is easy to build:
Old 31st October 2009, 03:52 AM   #9
Hi, I am new to this forum.
I also builded a E / PCL 86 SE Mono Block with EZ 81 rectifier.
This was for our THAI DIY Low Cost Project.
The price of the material should not exceed 10.000.- Thai Baht, around 200.- Euros.
The funny thing is, that the sound quality is very good.
A friend of mine has made me very good OPT for the E / PCL 86.
They are a little big but they deliver a nice bass.
It makes fun to listen to this Amps.
Old 31st October 2009, 11:12 PM   #10
Tubes4e4's Avatar
Hi TubeKing,
F.e, this one by Bill Douroukis: amp, B+ supply, heater supply.
If too complicated, you can start to simplify the B+ supply.
Regards, Tom Schlangen
If in doubt, just measure.
RH ECL86 Amp: Dave? pjanda1 Tubes / Valves 11 8th January 2012 08:44 AM
Filament for the PCL86 boessenkool Tubes / Valves 2 25th January 2009 07:54 PM
Better sounding ECL86's Robyn_E Tubes / Valves 2 9th August 2007 04:05 PM
PCL806 is equivalen to PCL86? Davidakosa Tubes / Valves 5 21st June 2004 01:33 PM
Page generated in 0.13881 seconds (55.25% PHP - 44.75% MySQL) with 11 queries
