I just got the DPDT switches to use as a selector switch on my next Simple SE's.
In order to figure out which connectors are what, I put a ohm meter on them and came up with 1.2 ohms when in position 1 and about 18 ohms in the other position (measuring other tabs) Is this acceptable? Will it reduce the output for one cd player vs. the other? Thanks, Paul |
#2 |
I'm a little confused here... 1.2 ohm in position 1 and 18 ohm in position 2? If you are measuring across the switch, you should see 0-ish ohm (1.2 is fine) in position 1 and infinity in position 2. If you measure 18 ohms in position 2, I'd say the switch is broken. I interpret "position 1" as "input 1 selected" and "position 2" as "input 2 selected".
If you are comparing two different switch pairs of the same component, I'd say that a 10x variation is kinda crappy, but as long as the contact is ohmic (i.e. not a semiconductor contact) you should be fine. The input impedance of the SimpleSE is on the order of 470 kOhm if I recall correctly, so the slight difference in source impedance from the different switch pairs won't matter much. ~Tom |
#3 |
Yes, for brevity's sake I didn't mention the 0 ohm readings which I did get without flipping the switch on the other contacts.
Thanks for your help Paul |
| Selector Switch Pop - Newbie Question | LHMAudio | Solid State | 5 | 18th May 2009 11:31 PM |
| Question: I need to build an AB switch for testing speakers | Taperwood | Full Range | 19 | 23rd March 2006 10:03 PM |
| Selector switch | Rnickl | Parts | 8 | 29th January 2006 07:12 PM |
| Selector switch on a T-amp? | triodesteve | Class D | 1 | 31st December 2005 05:04 AM |
| pre-amp selector switch | bonz | Solid State | 2 | 21st November 2005 04:37 AM |
