| diyAudio Sponsor | ||
. . a single channel using a 12AY7 and an EL84?
Any suggestions & advice will be mucho appreciated. If that combo doesn't sound right for a very clean ~5W, then I'd listen to reason if there's a good alternative> All the best Gerry |
#2 |
Gerry,
A 5 W. O/P means full pentode mode for the EL84. You said a single channel using a 12AV7 for small signal handling. OK, how about a LED biased, CCS loaded, 12AV7 section DC coupled to the 2nd 'V7 section setup as a cathode follower. That's plenty of open loop gain to drive the EL84 and the requisite NFB circuitry. Whether you go GNFB or short loop is a matter of personal preference. NFB of some kind around the power pentode is essential to obtaining a satisfactory damping factor. BTW, don't forget to regulate EL84 g2 B+.
Eli D. |
| Looking for a simple circuit | Skitch72 | Tubes / Valves | 19 | 12th August 2009 07:31 PM |
| HELP-- I need a simple 50W AMP circuit --- | MTO audio | Solid State | 5 | 9th August 2007 06:46 AM |
| Help me with simple circuit | valterdaw | Car Audio | 2 | 22nd August 2006 07:15 AM |
| comment on this simple psu circuit | jarthel | Power Supplies | 13 | 14th August 2006 07:26 AM |
| check my simple circuit | svokke | Solid State | 5 | 25th March 2004 06:19 PM |
| Page generated in 0.08569 seconds (52.65% PHP - 47.35% MySQL) with 10 queries |
