Old 7th March 2010, 09:30 PM   #101
Herr Grau's Avatar
Send a message via ICQ to Herr Grau
Well, the bias voltage, regulated via R21 and R31, produces a current through R32 and R33, which makes them the measuring points for the actual bias current. Since the resistor ist 10 Ohms, I regulated the bias voltage in a way that 650mV are dropped across each of them. I don't care for the actual voltage at the grid, I only measure over the cathode resistor.
Old 10th March 2010, 12:29 PM   #102
Herr Grau's Avatar
Important lesson: Don't ever drop a pizza in an amplifier!
I was lucky it was the other one which is still pretty early in it's building phase....
Well, soldering the other resistor to the input I somehow managed to shorten the input. Next days are going to be exams, so I shouldn't even be thinking about amps.. But afterwards I'm gonna fix that and try removing the PSU from the case.
That clearly shows, that I'm out of ideas.
Old 24th March 2010, 05:24 PM   #103
Herr Grau,
Exams finished yet? Curious to see if you had made progress?
Living Life Doing the Waltz in 4/4 meter.
Old 24th March 2010, 06:23 PM   #104
Herr Grau's Avatar
Exams are over now and I'm at my parents for a few days to get some R&R. When I get back home, I'll try all the things left on my mind, specificaly increasing the distance between the driver board and the chassis and removing the PSU from the case. I'll report back when I did.
Old 14th January 2013, 02:15 AM   #105
gabdx is offline gabdx  Canada
What happened?
Old 15th January 2013, 03:02 PM   #106
Herr Grau's Avatar
Hi. The amps are done, but I havent had real spare time on my hands for as long as the last posts, thus I havent written about it. Sorry about that. The hum problem was solved by moving the B+ supply away from the Pre-Stage. Now they just sound great. I can only recommend the circuit.
SE KT88 Amp Cassiel Tubes / Valves 50 24th March 2011 08:33 PM
Would it be possible? OTL/OCL KT88? Layberinthius Tubes / Valves 4 24th January 2004 11:31 PM
Copyright ©1999-2013 diyAudio
