With a little help... KT88 PP UL Amp
Old 5th March 2010, 10:31 AM   #91
SGregory is offline SGregory  United States
Herr,
Are all of your grid stoppers right at the base of the tubes?
Living Life Doing the Waltz in 4/4 meter.
Old 5th March 2010, 10:37 AM   #92
Herr Grau is offline Herr Grau  Germany
Herr Grau's Avatar
Send a message via ICQ to Herr Grau
Not realy, but there isn't a giant amount of wire between them and the socket either. I know that they are supposed to be as close as possible and with the output tubes I acutaly soldered them directly to the socket. But the one for the input stage has aprox 2" of wire. I can correct that though if rendered necessary.
Old 5th March 2010, 11:33 AM   #93
richwalters is online now richwalters
richwalters's Avatar
STOP!
DOUBLE CHECK the o/p stage tubes are correctly connected; screen grid to screen grid tap and anodes tap on each respective side of each half primary. Check you haven't got anodes and screens swapped. If it is wrong, this is the quickest way to ruin a set of good o/p tubes by destroying the screen grids.
TIP:-
When powering up for the first time even if correctly wired, temporarily use 470R 0.25W resistors in each screen grid (g2).....this will limit the screen current and will go o/c if something is wrong.
Old 6th March 2010, 12:13 PM   #94
Herr Grau's Avatar
I checked everything three times, all the values are right and everything is connected correctly, there are no short wires. The one thing I could possibly think of is that I didn't connect Pin 1 to anything. It's connected to the metal base of the tube. Should that be grounded? That really can't be it.
I don't understand why this blue glow thing should happen. The two sides of the OPT should be absolutly equal. Although of course I only use the 4 Ohm tap and leave the other ones unconnected, but that is really the last thing I could think of and it shouldn't matter either.
Old 6th March 2010, 06:36 PM   #95
Pin I is normally grounded. However, I've seen many designs which is just ignored. You need to ascertain that the output stage is drawing the correct current, as I suspect the blue glow could be high quiescent current. You need to measure the volts across the cathode resistors with no signal. For basic measurements I always start with quite a low value 40-50mA just to start off with. It can be increased later.
I've never known this kind of amp with 6SN7's to start oscillating; there should be no sign of oscillations, without global nfb.
Make sure you are working with a dummy load. The quiescent current should be quite steady.
richy
Old 6th March 2010, 07:57 PM   #96
Herr Grau's Avatar
The B+ is between 505 and 510V and I have set the quiescent current to 65mA running the amp in pure Class A. I can swap the phases again and measure what happens when the blue glow appears.
Old 7th March 2010, 02:46 PM   #97
Herr Grau's Avatar
Btw... I have redrawn the schematic, so it's correct and more readable:
Old 7th March 2010, 04:06 PM   #98
john65b is offline john65b  United States
john65b's Avatar
Herr, can you post critical voltages? Bias, Plates, Cathode, etc?
EDIT - whoops, just saw you posted some of the voltages on previous post...
"I have set the quiescent current to 65mA running the amp in pure Class A"
What power are you at in Class A at that bias and B+?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 7th March 2010, 06:58 PM   #99
Herr Grau's Avatar
Looking at the Genelax Datasheet, drawing a load line from 500V 0mA to 0V 250mA (Raa of the OPT is ~4k, so every tube should see 2k, right?) and looking at 65mA takes us to a bias voltage of -47V and a power out of around 24W per tube. But as always: I can be wrong.
Old 7th March 2010, 10:15 PM   #100
What is the voltage across R32 and R33 respective. Tube sheets are not accurate enough due to tube variation to set up by. Must measure to set it up correctly.
With a little help... KT88 PP UL AmpHide this!Advertise here!
SE KT88 Amp Cassiel Tubes / Valves 50 24th March 2011 09:33 PM
Would it be possible? OTL/OCL KT88? Layberinthius Tubes / Valves 4 25th January 2004 12:31 AM
