diyAudio Sponsor
Old 22nd October 2009, 07:08 AM   #1
Talking Regulated Tube Preamp question
I'm thinking about building Frank's ultimate tube preamp but am a little confused when it comes to the transformer for the power supply. He talks about a 300VA transformer. but in the parts list states 250V 300ma EI core. In another post it's stated that the transformer is 250V @1A. None of these correlate to me, and am not sure what to purchase.
Actually what I am looking to build is a quality tube preamp on the high end side. My theory is basic, but my building skills are high. Am I headed in the right direction with Frank's preamp?? Or should I consider something else?
My current setup is a 24 chip DDDAC dac and a upgraded/modified Cavalli Bijou amp. I also have the Buffalo Dac, but have been somewhat (ok, alot) disappointed compared to the DDDAC. I think this can be attributed to the IVY linestage. So my thought was to build Frank's preamp, and test with the Buffalo. If you can believe the Lampizator's write up... he rave's about the buffalo with a tube linestage. In any case...building a quality preamp would set me up for the next step...which would be to build a quality higher power tube amp for speakers (as to now, I have stuck to headphones).
Any comments or suggestions would be appreciated!
Old 22nd October 2009, 04:23 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
I'm not familiar with Frank's preamp but 300VA seems too much. If you could list the tubes used it would help.
Old 22nd October 2009, 04:45 PM   #3
It's actually an old thread on this site
Frank's Ultimate Tube Preamp.
Here's the PS:
And the Linestage:
Old 23rd October 2009, 07:54 AM   #4
ray_moth's Avatar
Thanks. The total power demand can't be much more than about 25w by my reckoning. Maybe I'm missing something.
Old 25th October 2009, 03:41 AM   #5
Geek's Avatar
Is it me, or is John Broskie trying to take credit for this preamp circuit as the "Broskie Impedance Multiplier"
Tetra Phono All-in-One & Broskie Impedance Multiplier
Cheers!
Old 25th October 2009, 08:31 PM   #6
Geek's Avatar
Just to append my comment, I discussed this with John and though they look alike, Reference Audio's is just a White-CF variation.
Cheers!
Tube preamp question...also, chassis layout jim_vt Tubes / Valves 1 22nd January 2006 12:01 AM
Regulated psu for tube preamp wuffer Tubes / Valves 21 15th October 2005 05:22 AM
tube preamp kit question (again?) monomonster Tubes / Valves 1 23rd September 2005 11:36 AM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
Tube Preamp PSU Question JojoD818 Tubes / Valves 13 19th January 2004 10:21 PM
Page generated in 0.10118 seconds (68.60% PHP - 31.40% MySQL) with 10 queries
