Some general opt questions.
Old 21st October 2009, 04:33 PM   #1
rman is offline rman  Canada
rman's Avatar
Default Some general opt questions.
Hi.
I just built a guitar amp using an Edcor gxpp output transformer. the primary winding did not have equal dc resistance on each half. One side read IIRC about 93 Ohms while the other side was around 84 Ohms. This was my first push pull amp as well. I was wondering if this would be of concern for the sound quality if building a hi-fi amplifier.
Also could anyone give a quick explanation for why the impedance ratio of a transformer is the square of the turns ratio?
Thanks.
Rolf.
Old 21st October 2009, 05:34 PM   #2
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Originally Posted by rman View Post
Hi.
Thanks.
Rolf.
It's not of concern to me. Some really nice OPTs like my vintage UTCs have unequal resistance. It just means one side is larger diameter turns. Maybe there are some reasons it's better to have equal resistance and equal diameter turns, but it's a small compromise if any.
The impedance changing as the square of the turns ratio can be explained mathematically. Faraday's law gives the basic relations of induced voltage and current. The voltage ratio is equal to the turns ratio (unloaded, etc) vsec = vpri * (tsec/tpri) ; the current ratio is equal to the inverse of the turns ratio isec = ipri * (tpri/tsec) ; the impedance (v/i) is thus (tsec/tpri) * (tsec/tpr) or simply the turns ratio squared.
Old 21st October 2009, 05:57 PM   #3
Yvesm is offline Yvesm  France
Yvesm's Avatar
Or you may simply apply Ohm law because the turn ratio IS the voltage (U) ratio and the inverse of the current (I) ratio.
Since Z = U / I, if voltage (turn) ratio is 4, then Z = 4/(1/4).
Rearanging gives 4 * 4
Yves.
Ooops ... bis repetitae ... sorry.
Old 21st October 2009, 11:26 PM   #4
rman's Avatar
Thanks guys.
Both answers are valuable because they are stated differently. I will ponder them both for awhile and the light will come on slowly like a tube filament. My brain doesn't work fast like turning on an led. The different ways of saying the same thing will help. Thank's again.
Rolf.
Old 22nd October 2009, 12:10 AM   #5
rman's Avatar
I get it!
suppose a transformer has a ratio of 10:1 and you input 100 volt AC, the output is 10 volt AC. Now put an 8 Ohm resistor across the output, 1.25 amps will flow through it. Now since the transformer is stepping up the current by 10, 0.125 amps flow trough the primary. R=V/I so R= 100/0.125 = 800. So as far as the 100 volt AC source is concerned, it has a 800Ohm resistor across it!
That is so cool
Old 22nd October 2009, 12:14 AM   #6
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
wow rman! yours is the best explanation I have ever read! Seriously! You should teach!
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 23rd October 2009, 01:56 AM   #7
rman's Avatar
Thank's!
I hope my head doesn't swell up too big Once I figured it out I figured I would throw in a practical example so any one else with the same question would have no trouble understanding. Then again, maybe working it out for themselves would be more educational. Anyway it's out there and might help someone.
Peace.
Some general opt questions.Hide this!Advertise here!
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 29th July 2014 11:14 PM
general chip questions Ropie Chip Amps 2 11th July 2004 09:05 AM
2 general sub questions, please Misa A. Multi-Way 3 22nd March 2004 05:54 AM
SOZ amp general questions MEGA_amp Pass Labs 4 27th October 2003 02:53 PM
Copyright ©1999-2017 diyAudio
