| diyAudio Sponsor | ||
Hey Folks,
I need a bit of help here. I am pretty green to this stuff. I have a Zenith EL84 PP console amp that I am modifying to a stand alone unit. Model is 7d31. I have attached a schematic, I hope it is readable. If you notice this has a fairly non-conventional set up with the OPT's. One opt feeds into the other. I would like to replace those with a more suitable, more traditional set up. Probably something from Edcor. Here is my question, on the schematic the opt's get b+ and then are connected to the plate. The screens are tied together. The opt's from Edcor show the b+, plate, and screen connections. IF I wanted to put in the edcor opt, I assume that all I need to do is change the connection on the schematic. Disconnect the screens from eachother and hook them into the screens on the new OPT;s. Is this correct? BTW, I measured the impedance on the current OPT's, and assuming an 8 ohm impedance load, the opts measure at 1.2k. I checked, double checked, and rechecked. They are 1.2k. Screwy as heck to me. Mu understanding is that EL84's need about 8k opt's Finaly, I noticed several other little things that need changed. For example, the resistor/cap in the feedback loop. I am going to copy the values from the HK230 ballad. It looks like a fairly similar ciorcuit. Change the values to 39k and 22pf for each side. SO, if you have any suggestions or can help, I'll owe you one! Mark |
#2 |
here is a blow up of the opt on hte schemtic - not very clear but ou might be able to get the idea.
#3 |
Found my answer. Thanks anyway.
| Zenith Console find, amp suggestions? | Eratosthenes | Tubes / Valves | 8 | 28th August 2008 05:20 PM |
| zenith mlt 15 console record player problem | tim614 | Tubes / Valves | 14 | 6th July 2008 03:33 AM |
| WTT: Zenith 9H984LP console radio/phono for fixable tube hifi amp/preamp | GordonW | Swap Meet | 0 | 21st December 2007 10:59 PM |
| zenith amp | diesel_tech | Tubes / Valves | 6 | 22nd October 2007 01:34 AM |
| Zenith Console Opt Question, Odd Secondary | Trout | Tubes / Valves | 10 | 3rd October 2005 02:20 AM |
| Page generated in 0.84824 seconds (8.43% PHP - 91.57% MySQL) with 11 queries |
