diyAudio Sponsor
Old 21st October 2009, 02:23 AM   #1
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default Questions on JE Labs transformer coupled line stage
So I'm thinking about building the JE Labs transformer-coupled design with a single 6SN7 instead of the 76s.
I found this thread on here, Transformer Coupled Linestage heard good things about James OPTs, so I'm tempted to try them for this project. Problem is, I can't find JS-3004Ns anywhere.
TC Tubes - specializing in vintage vacuum tubes that place has some of the James line, but not the preamp coupling ones. I'd like to get an idea how much they cost, so I know if this project is in my budget or not - $250 a pair is OK, $400 is not
Are there any other brands that would be recommended? One Electron, Magnequest, Lundahl? I saw some Lundahl ones at K&K Audio's page, but it was hard deciphering what the primary/secondaries were...
I have more questions, but that's all for now Thanks.
Jim J.
Old 21st October 2009, 04:23 AM   #2
kevinkr's Avatar
I can recommend both Magnequest, and Electra-Print for their plate to line transformers.. Another good option could be the UTC A-25 (eBay) as long as you keep current in the 6mA region.
The 6SN7 (consider 6C5/6J5 as well) will give you more gain than the 76.
www.kta-hifi.net
Old 21st October 2009, 04:51 AM   #3
Glowbug's Avatar
Thanks.
Is there a significant difference between the "regular" and nickel-core Magnequest ones?
Jim J.
Old 21st October 2009, 06:08 AM   #4
dsavitsk's Avatar
Nickel is generally higher permeability and lower distortion. It is definitly better when there is no DC on the core. But, with DC it will saturate more easily requiring a larger core, eliminating some or all of the benefit of higher permeability. Some people still like it better (Magnequest), and some think it a waste in this application (Electra Print).
FWIW, I think the rp of the 6sn7/6j5 is a little high for transformer coupling. I think I'd use a 6H30, 5687, 6922, ecc99, d3a, etc. instead.
http://www.ecpaudio.com
Old 21st October 2009, 06:17 PM   #5
Glowbug's Avatar
Good to know, thanks
If I went with the 6922, how would that change the other circuit components?
Jim J.
Old 21st October 2009, 06:37 PM   #6
mwiebe is offline mwiebe  United States
Jim,
I’m listening to a pre-amp like you’ve drawn (without the bypass cap and 600 ohm cathode resistor) through an Electra Print L3500 (10K/600--you can order headphone taps if that appeals). A pair will set you back $212 if the website is up to date. 10K is not what I would pick for a 6SN7 but in practice it works just fine. I have plug and play power supplies, 250V, 150V, 30V battery, and lots of different tubes, subminiatures and 7- and 9-pins wired to octal plugs, so I’m a tube rolling fool. Just build what you plan and have fun.
Matt
Old 21st October 2009, 06:50 PM   #7
revintage's Avatar
Hey Jim,
If you go for 6922 you will need a 4:1 transformer with at least 100H primary. You could run it at ca 10mA/150V Ia/Ua.
Why not let Dave Slagle at intact audio design and customwind a pair for you?
Brgds
Lars
Old 26th July 2011, 01:37 PM   #8
Hi, I have 15K to 600 plate to line but Plate current is limited to 6-8mA (UTC A-25)
Is this schematic OK with my line transformer ? How if I apply fixed bias at Vp=180V and -5/-6 at Vg
Anyone can help ? Any comment wuld appreciated
ThANK YOU
jj
Old 26th July 2011, 03:47 PM   #9
hi glowbug, obviously, I would stick with tx's that are home grown, simply as they are heavy, and will be expensive to ship from abroad.
unless its a mega project, I wouldn't spend a fortune and go with decent tx's apart from hi end ones, try hammond groan, or from abroad, pat turner from australia who's amazing. sowter's, silks, also if you wish to import, and also holland's AE are very good, but best home grown considering price really. james are good. tbh I think commercially, all are ok myself, have tried cheap and dearer and don't think dearer are worth cash reallyl. chinese were fine for me. obviously custom wound better tho' as bespoke.
lundahl's, yes but again, I find them impossibly complex. perhasp stick with edcor/ james/ slagle/ one electron
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
Questions about this line stage eapavant Tubes / Valves 4 7th September 2006 12:35 PM
EF91 Line Stage questions JDeV Tubes / Valves 6 16th August 2005 06:54 AM
Transformer coupled 6SN7 push-pull DAC output stage? cathode_leak Tubes / Valves 7 24th January 2005 07:26 PM
Balanced line stage Different transformer lykkedk Pass Labs 12 11th December 2002 10:32 PM
Page generated in 0.11147 seconds (76.11% PHP - 23.89% MySQL) with 10 queries
