diyAudio Sponsor
Old 18th October 2009, 11:48 PM   #1
Default What is a CCS - how do you design one?
Hi All --
I am working on a 6as7 tube amp in another thread with some helpful folks. The topic of using a solid state Constant Current source (CCS) consisting of a couple of transistors has come up. What is this CCS thing and how why does it increase the "swing" of the audio signal? I know a little bit about tubes at this point (long ways to go) but know next to nothing about solid state stuff. Is this technology worth my brain cell bandwidth?? thanks.
Old 18th October 2009, 11:52 PM   #2
MJL21193's Avatar
That is just priceless.
Old 19th October 2009, 12:02 AM   #3
aardvarkash10's Avatar
Page 133 onward of Morgan Jones - the bible.
Looks complex - took me ages to get my head around. Still don't fully understand MOSFET based CCS devices, but have just figured out MJE350 / MJE340 BJT ones...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 19th October 2009, 01:42 AM   #4
Magz is offline Magz  United States
Check out the IXYS IXCP10M45S, it's a complete CCS on a chip. All you need is an external pot or resistor to adjust the current and you're all set. You can cascode two of them for a small additional improvement.
I replaced the plate resistor in my Tube preamp with a cascoded pair of the IXYS chips and it transformed the sound; I now get holographic imaging and more gain with no downside I can hear.
Old 19th October 2009, 01:48 AM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I'll bite. Colorado Spinner with night crawlers on the treble hook?
A constant current source is an electronic circuit that provides a fixed current irregardless of the load impedance, within the limits of (1) the supply current, and (2) the thermal limitations of the circuit.
It can be as simple as a two transistor circuit or as complex as a LM317 (or other IC).
In most cases a single resistor is used to set the current magnitude.
How it effects the voltage swing will depend on the circuit in which it is encorperated.
More (specific) details in your question please.
What circuit topology will the CCS be used in?
Old 19th October 2009, 02:19 AM   #6
cbdb is offline cbdb  Canada
Forget the chip, 2 transistor and a couple of resistor is all you need for a simple CCS. (add a couple more transistors and you can make an excellent CCS.)
A transistors collector current (Ic) depends on the voltage across its base emitter junction (Vbe). Keep that voltage constant and you keep Ic constant(as long as the temperatures are the identical).
In the diagram the 2 trans. Vbe's are identical (wired to be that). The left tran. is conected to turn it into a diode, if the two trans. are identitcal and there Vbe's are the same then there Ics will also be the same. The resistor sets the current tru the diode, which in turn stes the current tru the other trans. That simple!
Old 19th October 2009, 02:28 AM   #7
dsavitsk's Avatar
Same basic concept -- there is a relationship between Vgs (voltage between the gate and the source) and Ids current from the drain to the source. So, you bias the gate such that there is a voltage difference between source and gate and this will correspond to a particular current flowing across the fet. With a depletion mode fet, like the DN2540, IXYS 10m45, 2sk170, etc, this is particularly easy to do. You simply put a resistor on the source and connect the other side to the gate. As current flows across the resistor, it drops a certain voltage that is used to bias the gate. Enhancement mode fets are biased the opposite way and require an external way to bias the gate -- often a zener and a resistor.
http://www.ecpaudio.com
Old 19th October 2009, 02:36 AM   #8
kevinkr's Avatar
The IXYs chips have measurably better AC performance, parasitic capacitances being what they are in bipolar transistors and even many mosfets, than the simple CCS shown above. This is particularly relevant as tube plate loads where the rp of the tube in question may be significant relative to the load impedance created by the CCS.
I think SY may have touched on this in some ancient posts and I have a number of highly analytical engineer friends who have devised experiments indicating that the more complex cascodes realized with particular mosfets or IXYs CCS chips were able to maintain a very high load impedance over a wide range of audio frequencies whereas the simpler CCS could not.
Depends where the CCS is used - in the case of the cathodes of a 6AS7GA/6080 for example even the 317 configured as a CCS will be adequate because of the low impedances involved relative to those the CCS is capable of generating.
www.kta-hifi.net
Old 19th October 2009, 02:37 AM   #9
Gordy is offline Gordy  United Kingdom
I remember reading a thread here which included a document on the implementation of a two-transistor cascode constant current source for tubes. I think it included values and a pcb design also.
Hang on.... (Gordy goes off and searches around the darkest corners of his hard drive)... yup, it seems to be called "diyAudio-CCS-beta2". Too big to post here. Have a search through the archives and I'm sure you'll be able to find the thread.
Old 19th October 2009, 02:48 AM   #10
TheGimp's Avatar
Change Q2 to a FET and the resistor to 1M and you get a lot more near ideal results.
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.15811 seconds (58.21% PHP - 41.79% MySQL) with 11 queries
