Need to regulate 450v --> 300v
Old 18th October 2009, 07:42 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Need to regulate 450v --> 300v
I want to use one transistor (mosfet?)and zeners.
the currentvis about 20mA at the 300v.
How?
Regards Åke
Old 18th October 2009, 08:31 PM   #2
Arnulf is offline Arnulf  Europe
Replace BJT with a MOSFET in this schematic. Add a capacitor (100 uF or so) in parallel with the zener chain if you want a "soft start" for B+ on top of regulation.
Old 18th October 2009, 09:22 PM   #3
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Don't forget a small heatsink. You're burning three watts.
Old 18th October 2009, 09:39 PM   #4
Ryssen's Avatar
Ok,thanks.
Regards Åke
Old 19th October 2009, 05:27 PM   #5
Tetrode is offline Tetrode  United States
Use a 6L6.
Look at the Grommes 260A for an example.
Old 19th October 2009, 10:58 PM   #6
Gordy is offline Gordy  United Kingdom
Tetrode means this one: Schematic - Grommes 260-A Tube Amplifier @ AmpsLab.com
6L6 open loop voltage reduction located near output transformer on the schematic.
Old 19th October 2009, 11:46 PM   #7
Ryssen's Avatar
Use a 6L6
Hmm,yes that way I get the heat ontop of the chassie and I get softstart,yes maybee..
Regards Åke
Old 20th October 2009, 12:14 AM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Like this:
You can use EITHER the tube or the MOSFET, whatever is your preference.
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 20th October 2009, 12:18 AM   #9
jan.didden's Avatar
.... or with a 6582 or 6080:
and get this performance:
http://www.linearaudio.nl/t-reg-1.htm
jd
Old 20th October 2009, 03:23 PM   #10
Ryssen's Avatar
I´will use a SS rectifier and a CLC filter,is it okay to use the 6L6 before the CLC?
I mean so the CLC get a soft start..or best to have it after?
Regards Åke
Need to regulate 450v --> 300vHide this!Advertise here!
can the 6n9s take 300v? (ru 6sl7) wicked1 Tubes / Valves 4 2nd October 2009 11:44 AM
Using Battery for 300v B+ ? mark02131 Tubes / Valves 14 6th March 2009 07:41 AM
Tubes power supply 220 t0 300V ? wrangler Tubes / Valves 2 3rd September 2006 02:36 PM
TL431: Can it regulate 300V DC? Danko Power Supplies 11 26th September 2005 10:45 AM
300V PSU for 6sn7 tube output stage in dac PTSOUNDLAB Tubes / Valves 0 17th June 2003 08:07 AM
