diyAudio Sponsor
Old 18th October 2009, 02:37 PM   #1
Default new to the forum and looking for el86 info
Hey folks, I just signed up today. I have spent some time over at audiokarma and a friend referred me to this site.
First, I am not to bright on this stuff, at least not yet. I love the sound of tubes and have been dabbling with it for a couple of months. I have learned a ton, but that is a small % of what I have to learn.
I recetnly purchased a set of lafayettes kt-a250's to build one good unit out of. These utilize a pp el86 configuration. Anyway, I am going to have this really nice extra set of iron perfect for the el86's.
I was wondering if anyone has a lint ot or a copy of a SIMPLE set of scheamtics for PP el86 amp???
I could duplicate the lafayette, but there has to be a simpler version around somewhere. I saw tubelab was working on this a while ago. Anyone know if there is a completed version?
Anyway, first and formost, hello!! I hope to get to know some of you well and even make some friends.
TTYL,
Mark
Old 19th October 2009, 05:46 AM   #2
boywonder's Avatar
I have no idea if this is relevent, but here it is:
EL86 Push Pull Triode Connection Diffrential Amplifier
It's a triode EL86 PP, yielding about 6W. It appears to use 5K output transformers; do you know the primary impedance of your transformers? Do you also have EL86 tubes? If you know the primary impedance of your transformers and are not married to EL86's, there may be lots of other possibilities..
Old 19th October 2009, 01:05 PM   #3
Thanks for the link. I haven't looked at it yet, thought I would answer first.
I actually bought two Lafayette a250 integrated's to be able to restore to one unit. As it turns out, I have a set of opt's and a ps that are good. The unit uses el86's. MY opt's are 3k pp. They have the b+ and then two wires for the plates on the input side. Also 4,8,16 ouput taps.
I have the schematic for the a250 integrated, but thought I would look to see if I could find just a simple stand alone amp for el86's. Any suggestion for that or any other use of these opt's would be appreciated.
Mark
Old 19th October 2009, 02:26 PM   #4
Shoog's Avatar
Consider this. The PL84 is the same as the EL86 with a different heater voltage;
My version of the Simple EL84 or rise of the anti-triode.
Shoog
Old 19th October 2009, 03:55 PM   #5
Shoog
I like this ALOT!
What is a an LM317? I have seen this before, but I don't know what it is. A potentiometer?
Old 19th October 2009, 05:04 PM   #6
Shoog's Avatar
The LM317 is acting as a Constant Current Sink. It replaces the Cathode bias resistor, but keeps the Current constant - which is important when using toroidals as outputs.
Shoog
Old 19th October 2009, 07:23 PM   #7
Assuming I build this with the standard transformers, as I already have them, would a standard resistor suffice?
Thanks again for the help!
Old 19th October 2009, 07:29 PM   #8
Shoog's Avatar
It would, but I consider the arrangement shown to offer many advantages over a simple resistor and so would recommend building as is shown.
Shoog
Old 19th October 2009, 07:47 PM   #9
SO, just to be sure I understand, would you build these with standard OPT's and the dcm, or go all out with the torodials?
I have the standard OPT's and it would probably save me somtething like $100 plus to use them.
Mark
Old 19th October 2009, 07:52 PM   #10
aardvarkash10's Avatar
the 317 is cheap, ubiquitous and (at least) an order of magnitude more effective than a resistor in this application. If shoog says use it, I would.
[edit] REGARDLESS of which transformers you end up using, use the 317s as drawn
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
anyone ever use el86/6cw5? mctavish Tubes / Valves 17 22nd July 2011 11:02 AM
EL86 and speakers? 800 Ohm iharris Tubes / Valves 15 8th November 2009 05:24 PM
anyone have any el86 circuits laying around? sousmielie Tubes / Valves 10 25th July 2009 01:30 PM
EL86 OTL krzanik Tubes / Valves 4 19th January 2008 03:37 PM
Page generated in 0.09724 seconds (82.24% PHP - 17.76% MySQL) with 10 queries
