diyAudio Sponsor
Old 16th October 2009, 12:40 PM   #1
cypher is offline cypher  Poland
Default CV6 / CV1135 / E1148 / VT232 VHF oscillator triode data
Hi
I'm looking for CV6 / CV1135 / E1148 / VT232 data sheet with average plate characteristics. Does anyone have experience with this tubes ?
Old 16th October 2009, 08:01 PM   #2
316a is offline 316a  England
316a's Avatar
Originally Posted by cypher View Post
Hi
Its the same as 7193 . 6J5 curves are identical
316a
Old 28th October 2009, 05:44 PM   #3
Thank you ;-)
Old 28th October 2009, 10:50 PM   #4
But be careful which cap you use for the grid and which for the anode - not the same as the 7193! The connections should be visible.
E1148,CV6-How do you distinguish the anode/grid caps? protos Tubes / Valves 1 6th February 2008 04:47 PM
8417 triode connected tube data rhcclark Tubes / Valves 0 5th May 2007 03:05 PM
2C26 &E1148's diesel_tech Tubes / Valves 0 2nd January 2007 02:42 PM
6gk8 triode pentode tube data Tony Tubes / Valves 4 16th November 2005 12:07 AM
data for 6V6 in triode mode? Joel Tubes / Valves 11 25th February 2003 08:07 PM
Page generated in 0.08788 seconds (54.76% PHP - 45.24% MySQL) with 10 queries
