diyAudio Sponsor
Old 15th October 2009, 11:04 AM   #1
bbbing is offline bbbing  Australia
Default Adjusting the sensitivity on a 6e2 magic eye tube
Hi there
I have a yaqin 5881 tube amp (schematics attached). I have done a few mods ie change the coupling caps and re-wire the output to triode. Does anybody know how to mod the magic eye tube / circuit so the peak level indicator displays at lower volumes?
I have tried shorting the 10k resistor from the 8ohm output tap. That increases the sensitivity a little however the volume still needs to be quite loud for the indicator to move. Any suggestions would be appreciated.
Old 15th October 2009, 02:54 PM   #2
HollowState's Avatar
Perhaps replacing that standard 1N4148 silicone diode with a more sensitive type like a schottky or even a germanium would help. Reducing or removing the .1ufd cap after the diode could also help. It's there to smooth out the rapid fluctuations of the signal and give a more stable indication. Of course you'll loose the intended purpose of a peak indicator.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 15th October 2009, 04:12 PM   #3
kevinkr's Avatar
Another possibility would be to take the drive for the 6E2 from one of the output tube plates and capacitively couple it and pad it down substantially. You could use a 100K resistor and 10K pot and this would give you a substantial adjustment range. Use a 2W resistor, and 1kV film or ceramic cap of about 0.022uF - 0.047uF or so.. And be careful as the ac + dc voltage components present with signal applied could be 700V - 1kV at full power depending on supply voltage. (Figure up to 2X the supply voltage at the CT of your OPT and you get the picture.)
www.kta-hifi.net
Old 15th October 2009, 04:31 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Use 2 small Shottky diodes as a voltage doubler.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 21st May 2010, 07:28 PM   #5
JimTube is offline JimTube  Germany
Originally Posted by bbbing View Post
Hi there
Hi bbbing,
did you get any good results increasing the sensitivity of the 6E2 tubes. I have the same amp and i tried a lot to make the bars gone @ normal volume settings. I hope you have found a way :-)
Regards ... Jim
The Magic of a Name 7N7 Tubes / Valves 9 1st December 2007 05:58 PM
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Math to calc optimal voltage of tube dac to match amp input sensitivity? riotubes Tubes / Valves 7 9th November 2006 11:08 PM
Page generated in 0.10016 seconds (66.77% PHP - 33.23% MySQL) with 11 queries
