diyAudio Sponsor
Old 12th October 2009, 01:35 AM   #1
tim614 is offline tim614  United States
tim614's Avatar
Default RH84 builder!
Im trying to get a winter project going and i decided to build another RH84 amp but with 6v6. My question is, what needs to change on the rh schematic for 6v6?
Old 12th October 2009, 03:42 AM   #2
tim614's Avatar
schematic
Old 12th October 2009, 03:55 AM   #3
frugal-phile(tm)
planet10's Avatar
At a minimum, you'll need to change the Cathode R on the output tube.
Maybe some optimization of the feedback R.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th October 2009, 04:18 AM   #4
tim614's Avatar
i do understand the bias need to be different between el84 and 6v6 but wasnt sure if there's anything else i need to know.
Old 12th October 2009, 05:14 AM   #5
aardvarkash10's Avatar
read the tubecad article on this subject and the classic Schade article. You may also want to look at Shoog's recent postings on the subject.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Last edited by aardvarkash10; 12th October 2009 at 05:15 AM. Reason: typo's make my incoherent statements indecypherable!
Old 12th October 2009, 12:07 PM   #6
Geek's Avatar
Checkout "Anode Follower" or "Plate Follower", because that's what this type of amp is.
Cheers!
Old 12th October 2009, 05:03 PM   #7
pointy is offline pointy  United Kingdom
pointy's Avatar
i would go for 250v for both the plate anode and the screen grid a very little bit under that.
it looks good on thd and you still get good watts also you can use the same opt
i think ?
Old 12th October 2009, 05:26 PM   #8
pointy's Avatar
you maybe able to push that up by 20v to 270v if i reme..................................
Old 12th October 2009, 08:21 PM   #9
tim614's Avatar
Im planing to build 2 monos cause i have a pair of 275ct PTX @75ma and EDCOR 5K8OHMS OPTX so ithought RH6v6 should be fun to build.
Rh84 Ptx tim614 Tubes / Valves 17 10th August 2010 01:28 AM
my third RH84 mctavish Tubes / Valves 12 11th September 2009 03:01 PM
RH84 based amp vanofmonks Tubes / Valves 5 7th August 2009 02:19 PM
RH84 vs Magnavox SE? ThSpeakerDude88 Tubes / Valves 33 30th August 2008 03:32 AM
Page generated in 0.13878 seconds (54.22% PHP - 45.78% MySQL) with 11 queries
