diyAudio Sponsor
Old 10th October 2009, 07:26 PM   #1
Default Steve Bench's LR Phono Stage - Cathode Bias Circuit Question
Would anybody care to take a crack at why Steve put R10/R23 into this circuit? Steve himself went off the grid a couple of years ago and is no longer reachable for his comments. I heard from one person who built a version of it using the Sowter Transformers that it was to put the bias diode into a more linear operating range but if that's true , why not do it with the first stage as well?
Any thoughts on the design as it is or suggestions for variations or possible improvements etc. to explore would be much appreciated.
Old 11th October 2009, 11:42 PM   #2
Sheldon is offline Sheldon  United States
That's an interesting one. The voltage figures for the respective cathodes don't add up. If it were done to bias up the diodes, then I don't know why it would skip the first diode in the string. Maybe to bias up the adjustment pot, or to lift the filament a little.
Sheldon
Old 12th October 2009, 12:29 AM   #3
No they don't add up. I've just been going through the curves for the diodes and the D3A and they don't really work out right. In Christian's schematic the pot is noted as being a 20Hz. adjust but with from 24mA up to 40mA going through the shared leg that pot is also needed for trimming the bias.
I'm going to build a simple version of it with AC heaters to start so no R10. We'll see how it works.
I don't know if you've seen his original article or not . Here's the link
Old 19th October 2009, 04:26 AM   #4
Default Calculate new Network Compensation in LR RIAA
Steve Bench's original LR Phono Stage design uses the LL1623 as the output transformer which is followed by an LR filter stage with resistor R2 in parallel with the L (labeled transformer compensation resistor in Christian Rintalen's schematic - also linked in the top post this page). If building this with the 1660 instead of the 1623 how would the compensation resistor value be adjusted? Would it be the difference in source resistances (seen looking back from the secondaries) added to the resistor?
Steve Bench LR Phono Amp. with (Sowter or Dave irons) snoopyma Tubes / Valves 0 5th September 2009 05:18 AM
Steve Bench's tube crossover nkg Tubes / Valves 16 16th November 2008 09:28 PM
cathode bias circuit question gary h Tubes / Valves 14 26th August 2008 12:36 AM
Steve Bench PP loadlines Klimon Tubes / Valves 0 8th November 2006 02:25 PM
Steve Bench OTL Klimon Tubes / Valves 9 17th September 2006 05:08 PM
Page generated in 0.13070 seconds (59.12% PHP - 40.88% MySQL) with 11 queries
