KT88 blocks? With E80CC + 6922 driver? - Page 2 - diyAudio
Old 8th October 2009, 11:03 AM   #11
KaffiMann's Avatar
Hi again.
I am reading up on the MonoBill, so far it seems interesting.
The reason why I posted that schema of the SE circuit, was that it had a very interesting way of dealing with noise cancellation from the PSU. And I was wondering if it would be possible to use the same principle in a PP amplifier. Because usually in PP designs (at least as far as I know), you are likely just about double the noise, as well as almost doubling the power output, compared to SE designs.
And I want something quiet, with a lot of power, using parts that I already have, and it has to be tubes.
Stereo Driver PCB for PP Amp (EL34/KT88)? Cobra2 Tubes / Valves 8 17th December 2010 10:50 PM
input/driver stage for kt88/6550 duderduderini Tubes / Valves 5 12th October 2010 04:21 PM
PP KT88 Mono blocks? TubeMack Tubes / Valves 38 11th June 2009 06:41 PM
Best driver for KT88 Triode SE. Kenneth Zhu Tubes / Valves 4 20th January 2008 06:19 AM
Any schematics for balanced line driver using 6922? leadbelly Tubes / Valves 13 24th February 2004 02:43 AM
Copyright 1999-2017 diyAudio
