diyAudio Sponsor
Old 5th October 2009, 10:03 AM   #1
WDYSUN is offline WDYSUN  Italy
WDYSUN's Avatar
Location: Southern Italy - London (UK) - Philadelphia (US)
Default Passive filter at tube amp input
Dear Mate,
Lynn Olson suggests to extend the bass response of his Ariel loudspeaker by using active filter to the low pass, the ARIEL would be passively filtered with a high pass between the preamp and amp, look at this:
http://www.nutshellhifi.com/ME2txt.html#swactive
Now, my question is how do I design such a filter? How to choose the series cap and the resistor to ground? There is any way to come up with a value? Has somebody experimented with such a thing?
Thanks for you interest.
Cheers
Pierre
Old 5th October 2009, 01:53 PM   #2
coldcathode's Avatar
Pierre,
Assuming that you are going to "dedicate" a tube amp to the high pass channels, it is as simple as either placing or "re-placing" the input coupling cap on the input tube with the correct value for the 80hz F3. You might need to change the grid load resistor to match well with the cap.
here is a calculator
I would need the schematic of you tube input to help further.
But an example would be .0047uF cap with a 390K grid to ground would give about 87hz F3.
A 200K and .01uF would be 79.6hz close enough?
Old 5th October 2009, 02:11 PM   #3
WDYSUN's Avatar
Hello,
for the mid-highs I use a Primaluna Prologue 4 (it's a 35Watts PP of EL34).
Pierre
Old 5th October 2009, 02:11 PM   #4
DougL is offline DougL  United States
To add to the previous comment, do not exceed the maximum cathode resistor in the data sheet. if the value of the grid leak resistor is too small, charge will build up and alter the bias point.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 5th October 2009, 03:17 PM   #5
According to the spec's I could find that amp has 100K input impedance.
So a .02uF cap gives you 79.6hz F3.
To make a test get a cheap RCA cable and put the .02 cap in series with the center pin.
Old 18th February 2010, 10:43 PM   #6
boudy is offline boudy  United States
Default Is it this simple?
Doesn't the output impedance of the preceding device need to be factored in?
Old 19th February 2010, 06:58 AM   #7
m6tt is offline m6tt  United States
I believe the online calculators assume a fairly low impedance looking into a high impedance, but I am not sure. I have generally assumed the calculators are close-ish for low impedance sources.
Old 19th February 2010, 07:01 AM   #8
Doug do you mean don't exceed the maximum grid resistance? I don't recall seeing a maximum cathode resistor spec in most data sheets. Also, I believe charge builds up when the grid R is large, i.e. greater than 1.5-5Meg, like grid-leak bias. I may not have totally understood!
Old 19th February 2010, 08:23 AM   #9
frugal-phile(tm)
planet10's Avatar
You can also just put a PLLXO in front of the amplifier.
The calculator linked above will do the math for a first order...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Bi-amplification to Dx Amplifiers, a passive input filter destroyer X Solid State 53 17th July 2009 05:16 PM
Passive filter for DAC? quantran Digital Source 15 2nd January 2005 03:28 PM
passive filter for sub moi Multi-Way 34 28th July 2003 02:12 PM
Page generated in 0.10738 seconds (76.09% PHP - 23.91% MySQL) with 10 queries
