Yes, I've searched. Can I use a PP OPT in a SE amp ?
Old 3rd October 2009, 09:44 PM   #1
Nihilist is offline Nihilist  United States
Default Yes, I've searched. Can I use a PP OPT in a SE amp ?
I have a pair of these http://store.triodestore.com/tf65wscta48o.html .
They are currently hooked up to a set of Reflektor 6p6s triode strapped(looks like 6N6C on bottle) which are similar to 6V6GT's . The circuit design is similar to the "Compact Amp" http://www.triodeel.com/compact.html which is fairly well known.
I am curious if I can run these OPT's in a SE format with the pair of 6p6s's run parallel , which currently draw 64ma combined. The OPT is rated for 80ma per side, so if run SE that would be a total of 80ma as the windings would be in series.
Would this be doable, or would I run into overtaxing the OPT ?
I understand I will have to rebias, etc, but if I can keep the current below the 80ma rating, would this work , or would I have to run a Parafeed type circuit ?
I am curious how the SEPT would compare to the Compact amp design.
Thanks for any help.........................Blake
Keep it simple
My Page Of SV1000 and DIY Stereo Links
Old 3rd October 2009, 10:03 PM   #2
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
The short answer is no. That transformer is made to have balanced amounts of current drawn across the halves of the primary. If you parallel the tubes, you will suddenly be drawing an unbalanced current, and the primary is not gapped for that use.
If you use parallel feed topology, you can try this type of arrangement, but there are other factors that will contribute to poor performance.
Old 3rd October 2009, 11:29 PM   #3
BudP is offline BudP  United States
BudP's Avatar
The long answer is no also. Any more than 5 microamps of DC will seriously eat up your core's working zone and cause poor AC signal, bass response. Along with this will come saturation that will cause ugly noises to emit from your speakers.
Sticking a 1 ufd expensive cap in series with the plate will block the DC and combine with the unknown capacitance of the OPT to cause the tubes all sorts of problems. Adding a plate choke will just add to the woe.
A parafeed set up is a VERY complex animal. There is no data sheet or information source, other than the RDH 4 section about RF amplifiers, that I have been able to find on these.
Doc Bottlehead's designer is justly proud of his skill with these things.
So, purchase as good a SE OPT as you can find and afford. Start with the usual suspects, Hammond and Edcore, find out what you do and don't like about the redesign and then spend some serious money for much better OPT's. Somewhere in there you will equal the current amps performance, except for distortion.
Bud
Old 4th October 2009, 04:26 AM   #4
Thanks for the heads up guys. Sounds like I'll stick with what I've got , as I'm pretty happy with it. Just wanted to know if some experimentation was possible with the parts at hand.
Keep it simple
Old 4th October 2009, 08:56 AM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
talkin just about principle , without checking exact xformers and other numbers - you can ;
Ub via primary halve to anode
cathode via other primary halve to gnd ;cathode must be AC bypassed to gnd.
naturally - primary CT must be interrupted
but - there is another issue - is half of primary adequate for your SE
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th October 2009, 09:56 AM   #6
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
The short answer is, yes.
The first long answer is, to use a string of incandescent bulbs at the opposite side of the tranny, to draw the current equal to the idle current of your SE output tube. Gain in tranny price/quality, but loss of power for balance.
The second long answer is, to use a CCS instead of a bulb. No loss of a singal power, but loss of B+ power still.
The thirt long answer, a conter-modulated CCS. More of power from a single SE tube, price/performance ratio of the transformer improved.
There were several such concepts discussed here; some on paper only, some SIMMed, some built as working prototypes.
The Devil is not so terrible as his math model is!
Old 27th December 2009, 01:43 AM   #7
Zen Mod "talkin just about principle , without checking exact xformers and other numbers - you can ;
but - there is another issue - is half of primary adequate for your SE "
Could you provide a schematic /drawing ? Not sure I follow this description.
Some things have changed since I first posted. Still using the same OPT, rated for 80ma per side, but I only want to run about 30ma SE thru it. Will I still saturate the core ?
Bud P commented that as little as 5 micro amps will cause problems. How could anyone even run a PP setup with cathode bias if this was the case ? 5 microamps of imbalance is very little, and I imagine is not too uncommon.
AM I nuts thinking this ? I understand that the closer the tubes are balanced in a PP setup the better it will work, but 5 micro amps seems impossibley small unless you are using a CCS to bias them and /or are constantly monitoring the current .
Thanks...........................Blake
Keep it simple
Old 27th December 2009, 02:48 AM   #8
BudP's Avatar
Nihlist,
5 micro amps of DC in a SE is a different animal from 5 microamps with an alternating AC current dragging it below zero every half wave. Yes there will be some slight saturation in a PP with imbalanced DC flowing, in alternate directions. Again, this is not like having DC current flow setting your core into an offset polarization.
Heck, your PP OPT is probably poorly made enough that it will withstand 20ma of DC current. Try it out. It's not likely to catch fire right away! If it starts getting warm to the touch within two minutes you have a problem, but mostly any problem willl just be poor sound quality. But, if the mfg. didn't pay very close attention to closing the E/I gaps for the lams, you might be home free.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 10th March 2010, 12:40 PM   #9
Nikon1975 is offline Nikon1975  Austria
Wavebourn, actually this would be a great idea to have SE OPT of reduced size. Let's say that we have two primaries: the first one for our audio use HV etc. The second one would pass a current sufficient to balance the magnetization of the audio primary. It does not need to be HV. Like this the iron would not saturate.
It sound too easy. What's the probem ?
Thanks,
D.
Old 10th March 2010, 01:01 PM   #10
bear is offline bear
expert in tautology
bear's Avatar
Why complicate things for the fellow??
The answer is NO, if you use it like a standard transformer.
The answer is YES if and only if you can A) remove the DC from the
primary windings or B) run the exact amount of DC coming from the tube in opposition (by some circuit trick means) to said DC, thereby cancelling the DC offset in the core.
The easiest way to do this is with what is called "parafeed" in this scenario there is a choke feeding the output tube DC and a cap feeding the OPT with AC signal.
_-_-bear
PS. there is a third option, that is to take the transformer apart, remove the lams and reassemble the E lams together, not interleaved, and then gap the I lams... but i'd go with the parafeed first and second one or more circuit tricks as a solution, sort of just buying a new OPT for SE operation.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Yes, I've searched. Can I use a PP OPT in a SE amp ?Hide this!Advertise here!
Yes I have searched drtool Introductions 2 28th March 2009 05:38 PM
YM3623 receiver searched beauty_divine Parts 1 24th November 2007 12:19 PM
Copyright ©1999-2017 diyAudio
