diyAudio Sponsor
Old 2nd October 2009, 05:58 AM   #1
Bengali is offline Bengali  United States
Default Aikido Resistor Help
I have two boards from tubecad. the older 9pin stereo board and the newer 9pin All In One.
I have some 6N1P tubes I would like to use on both boards. +B will be 250V.
I currently have on the All in One gate resistors as 300ohms and R6,R7 as 221ohms. I lost my notes so don't remember why I selected these values.
Please help me with the correct values so I don't kill myself. Thanks!
9 pin Stereo:
R2,R4 ?
R3,9,10 ?
R8, R11 ?
9 pin All In One:
R2,R5,R8 ?
R3,R4 ?
R6,R7 ?
Old 2nd October 2009, 07:54 AM   #2
Stixx is offline Stixx  Germany
Stixx's Avatar
9 pin Stereo:
R2,R4 ?
R3,9,10 ?
R8, R11 ?
9 pin All In One:
R2,R5,R8 ?
R3,R4 ?
R6,R7 ?
I don't know the All In One-Boards, but I assume that the parts denotation is the same as on the RevA. boards.
Edit: it is not the same!! Just looked it up, so everything is slightly different...
parts values stay the same though since the schematic itself remains unchanged.
9 pin Stereo:
R2, R4 cathode resistors of the first stage 221ohms
R3, 9, 10 grid stoppers 300ohms (value can vary slightly)
R8, R11 cathode resistors of the second stage (WCF) 221ohms but could possibly be run hotter...? (150ohms)
All In One:
R2,R5,R8 grid stoppers 300ohms (value can vary slightly)
R3, R4 cathode resistors of the first stage 221ohms
R6, R7 cathode resistors of the second stage (WCF) 221ohms
Hope this helps
Old 2nd October 2009, 02:30 PM   #3
Hi Stixx,
yes, VERY helpful. Thanks so Much!
what does WCF mean?
Old 2nd October 2009, 08:03 PM   #4
Stixx's Avatar
Originally Posted by Bengali View Post
Hi Stixx,
what does WCF mean?
WCF = White Cathode Follower
Aikido Resistor Help Bengali Tubes / Valves 2 11th May 2009 11:11 PM
Need help on resistor values for 5687 aikido kit atenolol50 Tubes / Valves 0 24th September 2008 02:00 AM
Aikido warm-up hum, resistor types, etc. cbutterworth Tubes / Valves 24 6th March 2007 03:28 AM
resistor and capacitor values for Aikido preamp cbutterworth Tubes / Valves 8 26th October 2006 08:21 PM
confusion in the resistor/capacitor values and B+ supply for the aikido jarthel Tubes / Valves 1 23rd May 2006 12:58 PM
Page generated in 0.07777 seconds (73.83% PHP - 26.17% MySQL) with 10 queries
