#47 DH pentode operated in triode
Old 17th May 2003, 03:32 PM   #1
alan_982002 is offline alan_982002  Hong Kong
Send a message via ICQ to alan_982002
Unhappy #47 DH pentode operated in triode
Hi All,
I am looking for information for #47 operated in triode mode, anyone have tried it before? what is the V/I characteristic? and what is the best operation point?
Alan
Old 17th May 2003, 11:34 PM   #2
Dedessus Totof is offline Dedessus Totof  France
Default 47 pentode
Hi Allan
you can go to this
http://frank.pocnet.net/sheets/021/4/47.pdf
Good luck!
Old 18th May 2003, 04:15 AM   #3
Hi Dedessus,
Thanks for information. It seems that the URL cannot be access.
Besides, i've take a look on RCA databook RC-13, it does not show #47 triode mode operation curve, pls advise.
Alan
Old 18th May 2003, 09:05 AM   #4
Default 47 pentode
Sory Allan try with this url
And put in the case search (47),after you can download the pdf files and view some graphics.
I just scan two schematic of 47 (single-end and push-pull),
both of the 30's.
If you are interested, tell me
Good luck
Old 18th May 2003, 10:10 AM   #5
Hi Dedessus,
Yep, pls send me the schematic.
IN fact, i just want to use #47 to drive my 300B with using interstage trf, pls comment!
Alan
Old 19th May 2003, 10:02 AM   #6
Hi allan ,i remember now where i see something about the 47
and the nearly same tube 42 except for the heater (6.3 volts,direct heating)
After all you can find in the last url the pdf file of the 42 from
General electric but it's in french .
they talk about the replacement from the 47 by a 42
and tell about uses in triode with 42 in interstage,in triode
If you have 1 of those you can see is the same construction of valve,strange now!
Pearhaps with the value of the 42,you can find solution to your project.
I try to compress the schematics and send to you
Good luck
Old 19th May 2003, 10:04 AM   #7
Sorry is not GE but Sylvania PDF
GOOD LUCK
#47 DH pentode operated in triodeHide this!Advertise here!
Pentode to Triode Switch Sherman Tubes / Valves 40 6th February 2013 12:06 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
triode vs. pentode for pp output. 9am53 Tubes / Valves 1 17th March 2005 07:34 PM
SE Pentode or PP Triode ? percy Tubes / Valves 37 8th October 2004 10:21 AM
triode=>pentode Lico Tubes / Valves 3 7th April 2004 07:08 PM
