| diyAudio Sponsor | ||
What do say: MJK, Kenpeter and others? Seems like this has been around here for a long time.....
http://www.tubecad.com/2009/09/blog0171.htm
Brgds Lars |
#2 | |
Current sensing master-slave push-pull is certainly not a new idea. The series anti-triode is toplogically like SRPP and the parallel, cathode sensing anti-triode is topologically like a differential LTP, with similar current loops. The plate sensing versions also have lots of prior art and some patents. One thing different about our work is that we are exploring the sonic aspects of high-gm slave devices as the "anti-triode". What we have also done here is explore even more topology variations (for example fixed or servo-controlled DC output, developed different control and feedback strategies, and done a lot of practical work on real world implementations. For anyone wanting to understand the current loop operation of this circuit, JRB gives a good detailed explanation with math: http://www.tubecad.com/may2000/page12.html Cheers, Michael PS after 30 years working in computer architecture, on "new" ideas, it clear to me that ideas are a dime a dozen. Outside of theoretical physics, the real challenge is in getting stuff to work. |
#3 |
Exactly what I was after. Got a little irritated as JRBs presentration of his "innovation" was like it was something new. Only the name "SRPP+" is........
Brgds Lars |
#4 |
When JRB cites *us* in *his* column...
#6 | |
diyAudio Moderator Emeritus
#7 |
#8 |
I agree with Michael, the driving idea behind "anti-triode" was preservation of the triode signature. This pointed to approaches using high gm devices, gm boosters, Op Amp loops etc, to preserve the spectra. The modified SRPP or "SRPP+" (first time I have seen that, but a nice article) and modified LTP topologies were convenient ways to implement this.
I wouldn't be surprised if some lab researcher came across the same ideas long before us, maybe even published them in some obscure journal. But long forgotten in the economic practicalities of the audio market. Hawksford Error Correction, for example, was invented and patented long ago by LLewelyn for tube circuits (Hawksford noted the origin), but ever see a tube amp with EC? The current mirror and voltage mirror circuits were invented by some Japanese researcher using tubes, but lost in the noise when neg. feedback was discovered. The Aikido first stage is the classic voltage mirror. If you really want to be impressed with lost tube technology, look thru some early analog computer texts using tubes. Simply amazing what could be done. Don
Ohms Law V = I R Last edited by smoking-amp; 29th September 2009 at 03:14 PM. |
#9 |
Sent him a Differential White Cathode Follower design for comments a few
months back. I thought a simple twin triode circuit with near perfect CMRR and PSRR (maybe useful for DAC?) would have been right up his alley? Never heard anything back... Not a peep. I never mentioned anything regarding the Anti-Triode. Didn't want him to think I'm completely nuts. Not yet anyways... Mind you, this sim run was undertaken with HUGE amounts of power supply and common mode noise. If it looks a little squiggly, theres good reason. When all the crud magically cancelled out, I immediately thought "Broskie!". Maybe I don't understand the guy, thought cancellations was his thing??? I would never have predicted him to take interest in Anti-triode SEPP. Last edited by kenpeter; 29th September 2009 at 03:37 PM. |
#10 | ||
The info on this site is very interesting (augmented cathode followers, etc.) http://www.jrossmacdonald.com/ but there must be others? |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area | baileyler | Swap Meet | 0 | 14th January 2009 02:07 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.12401 seconds (78.59% PHP - 21.41% MySQL) with 11 queries |
