Old 28th September 2009, 12:19 PM   #11
oshifis is offline oshifis  Hungary
Having read the topic title, 3-phase electromotor jumped in my mind. There are 3-phase power distribution systems, too. The only difference is that we have music, not a single frequency that can be described by a single constant speed rotating vector...
Old 29th September 2009, 06:10 AM   #12
whoa! that is a thought. I can see something happening here I never expected. Wheels are turning.
Old 29th September 2009, 06:45 AM   #13
multiphase switchmode in/converters are possible and extant, is that what you meant?
where multiple phase shifted bridges feed a common out, to roughly divide the output ripple for a given output capacitance of the filter, by the number of bridges afaik.
your very cpu power feed may have it ;p ridiculous currents btw, say 30 A :O
Old 29th September 2009, 12:30 PM   #14
Tom Bavis's Avatar
Here's an article from Radio Electronics (1956) that shows "extended class A" - parallel push-pull with class A and class C coming in on peaks.
http://www.audiophool.cjb.net/Misc/RE_5-56.pdf
Old 29th September 2009, 05:44 PM   #15
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Heh... Walker patented Current Dumping 20 years after it was published by somebody else.
Approximately at the same time when he patented it I made my class A+C SS amp independently...
Thank you Tom! Unfortunately, I can't click "Thank you" button: they were expired.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 10th May 2010, 09:27 PM   #16
Originally Posted by smoking-amp View Post
Well, one could just cheat:
Class Double A - diyAudio
A similar setup that has been used before has triodes for the 1st level and pentodes for the higher power level. Grid biasing determines when each tier parallels in.
For an example, if you can find a copy, this in Tremaine's "Audio Cyclopedia", the combination triode/pentode circuit is shown in Figure 12-130. It is described as "extended Class A". I was searching the forum for "extended Class A" because I am interested in building one of these, and the search led to this thread.
scoop
Old 10th May 2010, 10:02 PM   #17
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
They do that. It's called a distributed amplifier.
Amplifiers are arranged along a pair of transmission lines, so that the input is applied to each amplifier in turn, phase shifted as it goes. Because the capacitance and impedance of each amplifier acts on its own segment of the transmission line, they are able to operate sort of independently, so the output signal is built up as it travels down the line.
At low frequencies, the transmission line reduces to a simple wire, and you have a simple parallel output.
Tim
Seven Transistor Labs
Projects and Resources
all possible permutations of series parallel and phasing amplexus Instruments and Amps 0 23rd December 2008 11:31 AM
Orientation and phasing of transformers? Skorpio Solid State 0 29th July 2008 12:35 PM
feedback phasing audiofan Tubes / Valves 1 8th December 2005 05:56 PM
phasing problems on front components bser Car Audio 1 14th December 2004 03:32 PM
Phasing Tweeters ZiprHead Multi-Way 1 15th December 2001 12:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
