| diyAudio Sponsor | ||
Hi All,
Just wondering whether anyone has done any work with putting a bias on G3 in a beam tetrode. Putting around +60V on the suppressor grid on a transmitting pentode with a separate pin out for G3 does nice things to the curves of the big-ish transmitting true pentodes (eg 814, 828, 4E27 etc) according to the datasheets. Is a similar phenomenon possible (or likely) with the 813 beamie, which does have a separate terminal for the beam forming plates, even though the data sheet I have keeps it at 0V for all applications listed? I'm thinking primarily of 'pentode' connection here. Having said that, I'm also interested in the possibility of triode mode with 813 and here the beam plates could be at anode potential, or filament potential, or even a small +ve or -ve bias (but close to 0V). Any experience and/or thoughts? TIA, Andrew |
#2 |
I have seen this mentioned with the larger sweep tubes, ostensibly to help reduce the many hilariously named oscillations like "snivets". I have also heard of this being done with vari-mu pentodes to make them sharp-cutoff. For what it's worth, it can't hurt to try.
#3 |
Abj1,
I do not have the asked for experience, but have difficulty to imagine why I would apply a high voltage to beam-forming electrodes. They are there after all to limit electrons going to the 'sides' of the emission bundle where they do more harm than good. To now draw some electrons towards them does not make sense to me. But perhaps someone has experience as you ask. |
#4 | |||
#5 | |
#6 | |
cheers, Douglas
the Tnuctipun will return |
#7 |
diyAudio Moderator Emeritus
The 813 certainly looks like a beam tetrode, according to RCA http://r-type.org/addtext/add064.htm
#8 |
I don't have any 813s here to break open and check. If what you're saying is true, then the ARRL Handbook has been wrong for many years now, because that is what they've been saying for most of the 1960s issues.
#9 | ||
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#10 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Pin # Five is the supressor grid on the 813.
The physical distance was increased as much as possible from G2 to the Anode on Beam Tetrodes.....that helped low velocity Electrons from migrating "backwards". __________________________________________________ ___Rick...... |
| Biasing | fauxpas | Tubes / Valves | 4 | 3rd January 2008 08:06 AM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| SE OPT's & Biasing | eeka chu | Tubes / Valves | 45 | 5th April 2004 10:54 AM |
| SOZ Biasing | vdi_nenna | Pass Labs | 21 | 2nd June 2001 03:38 AM |
| Page generated in 0.11510 seconds (82.32% PHP - 17.68% MySQL) with 10 queries |
