| diyAudio Sponsor | ||
Have searched but havent found any info on this,what I know is that the gain becomes close to 1.and the driveswing must be more.'any thoughts on this ideas,fixed bias will be used,Schemas and reading..?
Regards Åke |
#2 |
what load will it drive? do you want to use a center tapped choke, center tapped symmetric autotransformer, or regular output transformer (will have quite strange specs)? this matters because plate voltage and idle current, bias and operation mode and required driveswing, can be optimized.
#3 |
I am going to use a LL9213 P-P, a lundahls trafo,I have e.maild him about data,they are about 10-14 years old.
What is a center tapped choke good fore?
Regards Åke |
#4 |
ah, do you have a link to datasheet?
a center tapped choke would let one connect a speakerload directly, and symmetrically to the cathodes of the tubes. but with most speakers, that works best with many pairs of tubes ;p or with some mosfets, like a member, susan parker, as i recall ;p though she used a transformer indeed. may be interesting for you to search perhaps. you will need to bias the "other way" though (depletion mode devices) ;p |
#5 | |
I searched the net on 6c33c and there is not much info on this,like how to calculate the drive swing for the 6c33c in this coupling,I know its going to be quite large.
Regards Åke |
#6 |
The LL9213 is the same as LL1623
http://www.lundahl.se/pdfs/datash/1620_3_7_9202.pdf And it is connected as 1,6k,but I guess that can be halved by using 8 or 4ohm wich is it? Anyone have cloue of the workingpoint of the 6C33 in this arrangement?
Regards Åke |
#7 |
well, i am not sure, but as is, it seems too high a load.
however sofar it seems that this thing is useable though, if rewired. 2 series 2 parallel primary seems to result in about 11:1 impedance ratio, which seems better in the ballpark. the grid swing is the grid drive, on top of the output swing, iirc, in this case. which may be more than 300 V ths dude has a 5x 6c33 driving 8 ohm, for 20 watt out, with 2.5 to 1 turns, i believe a pair in pp can deliver the same, and with a higher ratio, (3.35 with that trafo), you may hit over 25 W class A. http://www.super-otl-audio.com/Description.htm since this amp has less cathode swing, his grid swing drive requirements are also less (maybe half, or less, afaik) i have to think of more ;p what to think of 155V, 350 mA, about - 50V, and 400 Ohm seen each tube? a bit over 200 V swing,54 Watt idle, class a inductor theorem 25% efficiency ~ 25 Watt out for pair? seems about right, any expert opinion? Last edited by jechentau; 25th September 2009 at 06:15 PM. Reason: link and addition |
#8 | ||
Like this? ![]() What will the Primary restans be then,at 8 ohms sec. Quote:
Regards Åke |
#9 |
i guess the windings thus yes, but let someone check.
8 ohms sec. will be about 880 ohms, or 440 ohm for each tube. so the voltage could be a bit higher, and the current a bit lower, but same story yes, peak to peak again, let check plz ;p actually the windings are suboptimal, can be better arranged for wider bandwith. i think edit: actually it seems a trade off between bandwith, or dc balance, but for best bandwidth i guess one can best put both inner coils parallel, and both outer, and place those combos in series, with the middle as center. but let check. Last edited by jechentau; 25th September 2009 at 07:56 PM. |
#10 |
Regards Åke |
| 6C33C-B. PP or SE ? | Predator864 | Tubes / Valves | 471 | 14th February 2011 09:30 PM |
| 6c33c PSE | mark_titano | Tubes / Valves | 13 | 20th December 2010 04:49 AM |
| 6C33C-EB / 6C33C-EV extended life ? | ger56 | Tubes / Valves | 2 | 14th October 2007 05:54 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 20th September 2005 07:36 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 8th September 2005 02:41 PM |
| Page generated in 0.10251 seconds (81.97% PHP - 18.03% MySQL) with 10 queries |
