P-P Katodfollower with 6c33c P-P Katodfollower with 6c33c - Page 2 - diyAudio
Old 25th September 2009, 08:12 PM   #11
jechentau is offline jechentau  Netherlands
yep i guess so
wait i was focussed on the text, and thought 1x8, but on hindsight it might be best to align all from left to right in series indeed, because it may be best to keep the dc carrying parts (primary) as low DC resistance as possible, and i believe sofar this is indeed the best configuration.
but let someone else chime in please
addition: actually, it seems one can connect inner 2 of secondaries in series, then 2 outer next in series, then next 2 outer, etc.
Old 25th September 2009, 09:16 PM   #12
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Waiting..
Regards Åke
Old 25th September 2009, 10:19 PM   #13
i think have something wrong with the impedances, it may turn out that 2 inner parallel for one tube, and 2 outer for the other, and all secondary in series, but such to have least capacitive coupling, is ok.
i'm too tired and fuzzy now, goodnight ;p
Old 25th September 2009, 10:52 PM   #14
actually, in one whisp of waking clarity (needs to be verified ;p), it may seem that one half (the inner for instance, may be a advantage achievable) for anodes, the other 2, for cathodes, turns out the way to go to make this trafo work with 2 x 6c33 and 8 ohm.
but now getting really late ;p
P-P Katodfollower with 6c33cHide this!Advertise here!
6C33C-B. PP or SE ? Predator864 Tubes / Valves 475 4th June 2013 05:06 AM
6c33c PSE mark_titano Tubes / Valves 13 20th December 2010 04:49 AM
6C33C-EB / 6C33C-EV extended life ? ger56 Tubes / Valves 2 14th October 2007 05:54 PM
WTB 6c33c-b woody Swap Meet 0 20th September 2005 07:36 PM
WTB 6c33c-b woody Swap Meet 0 8th September 2005 02:41 PM
Copyright ©1999-2017 diyAudio
