I'm Building an Amp with a 6X5GT PS. It has 114v at Pins 3 & 5, which is Right, and it's a CLCRC Supply...But it has -.8v at Pin 8...I've tried 3 other Rectifiers, but they all show -.8v at Pin 8....Are my Pin-Outs Wrong??...The Heaters Glow, so at least they're Pinned Right???...
between pin 8 and where exactly? If Pin 8 is at -0.8v, and your other test point is connected to the signal ground elsewhere in the circuit, the voltmeter is telling you you have a resistance between the rectifier cathode and the signal ground...
Your pin outs are correct. Pin 8 is the cathode and you should have around +150VDC unloaded with respect to DC return/ground. Either all 3 tubes have an open cathode connection, which is unlikely, or your tube socket isn't making a connection at pin 8. Check that very carefully.
Is this a full wave with a center tapped transformer?
Oh Well, Live and Learn...It would seem that I've totally Screwed the Poodle on this project...I tried to do the Back to Back 12.6v CT RS Transformer Trick..But I only have 114v between Pins 3 & 5.....Nothing between either of those and Ground...It really looks Nice & Glows Pretty though...
- Tubes / Valves
- 6X5GT PS Problem
