No, you don't. However using two chokes will improve the channel isolation, and improve cross talk performance. It looks like the RH807 was intended for stereo, and being a single-ended design, there is no AC nulling such as occurs at the center tap of a PP OPT. In this case, it would be wise to split the RLC ripple filter so that each channel has its own ripple filter.
Thanks Miles!
Yes two chokes will improve cross talk that i understand, i was trying to save some $$ with only one choke but wasnt sure, i have built 2 RH84 with great result so i was planning to stick with the RH84 power suply but with higher voltage power trans if thats possible.
Tim
Tim
