6U7-G as driver in a RH 807?
Old 22nd September 2009, 09:34 PM   #1
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Default 6U7-G as driver in a RH 807?
Nice looking tube (yeah, form over function is not a good starting point, but hey...) that mimics the shape of the 807. Some NOS items listed here in NZ at a reasonable price, so would make an easy option.
Specs here - http://www.mif.pg.gda.pl/homepages/f...049/6/6U7G.pdf
Thanks all!
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 22nd September 2009, 11:55 PM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
From the spec sheet: "triple grid, super-control amplifier". That's an old timey way to say "variable-u". This is not a good thing, and the plate characteristics look hideously nonlinear. The 6U7 was obviously designed for use as a grid biased controlled IF amp for superhet xcvrs. In that case, they didn't care about linearity since the harmonic distortion is filtered out with double tuned IF interstage xfmrs.
Might be useful if you triode it?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd September 2009, 07:23 AM   #3
Default thanks Miles
I kinda figured that since they were available, they must be unusable, but sooner or later I must strike it lucky! Triode? Yeah, but defeats the purpose of a pentode driver for the RH807... Still, if I was any sort of adventurer, I should give it a try anyway - in the spirit of constant learning.
Cheers!
Old 23rd September 2009, 07:58 AM   #4
Shoog is offline Shoog
Shoog's Avatar
Essentially I agree with Miles. There are far better candidates out there.
Having said that, looking at the curve given it looks as if biasing at -5V might just be workable. assuming an input signal of 2v it shouldn't stray outside it linear range to much. If its not to much trouble you could breadboard it up and see if it works.
Shoog
Old 23rd September 2009, 08:12 AM   #5
Originally Posted by Shoog View Post
Essentially I agree with Miles. There are far better candidates out there....Shoog
Sonically and electrically, you are both probably right. But like the mechanical gob-fest that was the Renault Alpine GTA, this thing is pretty!
Thanks guys - wiser heads and all that.
6U7-G as driver in a RH 807?Hide this!Advertise here!
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Copyright ©1999-2017 diyAudio
