| diyAudio Sponsor | ||
Dear Gents,
I would like to do a DIY monoblock SE with the following config: 833A or C /Kt88 or 300B / WE437 or 6C45. (150wpc) somebody has the schematics of the circuits and the power supply. I hear that is not so easy and very dangerous, also im from Chile which difficults the things a little bit. therefore I will need to import a few things, therefore if also somebody has the picking list, will be also much appreciate. Other things Wavac schems are the best for this or is somenthing better. please advice and sorry for bother the comunity, I been searching the net without much success |
#2 |
Gents,
what do you think about this config for myproject 833A/C config(Class A single end): 833A/C,12AX7*1,6SN7*1,6V6*1 per chanel/monoblock Max Output power:100W*2 Frequency Response:20-20KHz Distortion:≤1% Signal to noise ratio:≥80dB Input sensitivity:700mV Input impedance:100KΩ Output impedance:4Ω/8Ω Weight:80KG each monoblock Pros and Cons more than welcome, also how much should cost somenthing like that Jesus |
#3 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
This is going to cost you the price of a very nice new car.
The transformers alone will most likely be custom made, will cost at least a thousand US Dollars each and you will need several of them in all configurations. This type of amp is only for the VERY experienced builder and asking a rookie to try it is like asking a regular fellow to jump into a Formula One car & go race it. __________________________________________________ _______Rick...... |
#4 |
Honestly, that's the sort of amp to which the following rule applies: if you can't design it yourself, don't do it...
| Amplifier using a 833A | Tekko | Tubes / Valves | 17 | 15th September 2009 01:02 AM |
| 833a Amp 75W SE | dominic_tollens | Tubes / Valves | 5 | 14th December 2006 02:12 AM |
| FS 833a tubes & caps | woody | Swap Meet | 2 | 18th September 2005 01:52 PM |
| tube 833a | wasibi | Tubes / Valves | 0 | 22nd April 2005 09:00 AM |
| 833a plate resistance ? | woody | Tubes / Valves | 8 | 5th August 2004 03:06 PM |
| Page generated in 0.07451 seconds (77.49% PHP - 22.51% MySQL) with 10 queries |
