Anyone know a source for these? I need two for an amplifier project.
Don't bother ! These are a real P.I.T.A to use . If you find some which have been handled roughly , the filament can break in transit , incidentally the filament draws in excess of 4a . 50% of these that were in my stock had translucent rather than brown getters , a good proportion were also gassy . These do look pretty when fully functional and sound ok but I don't believe the 703a is anything special . The worst thing about the 703A is that the valves lose emission very quickly if running with a few mA or more . Avoid strain on the pins at all costs also !!!
316a
316a
Thanks for the advice! Actually I was aware of the limitations, but I became intrigued with peter millet's "glowing hybrid amp" and decided to give a go to building one. I have the board he designed and most of the components needed, so now all I need is a pair of unmolested tubes.
He wrote that he wanted it to sound something like a 300b amp, and I am curious to find out if he pulled it off.
316a
I've seen two versions of 703A's - one has a getter, one does not.
The one with the getter I've had no issues running at low current for some time. The ones without - and that includes the WE variation, I forget the number - 358A? - need to be run with the plate glowing.
Pete
Pete
Interesting that there is a non-gettered version but I guess it's going to be pretty useless 3C24 is a nice easy to use 'full cherry' type , British versions by EEV and Elliot take a lot of abuse before the anodes begin to glow though . I have some WE388A which have a triangular slab of carbon for an anode . These also appear to have the emission problem as the 703A which is a shame as these test very much like a type 10 . 316A is a good one , you can get good sounds at around 10mA and not too difficulkt to mount , again this type loses emission quickly if driven hard .
316a
Good info on this thread. I have some WE 368A's without the getter and planned on using them as a driver for a bigger tube. With the low filament voltage AC heating doesn't sound like it should be a problem? For sockets I used some press in turret sockets from Mill Max in a teflon disc. Not exactly idiot proof but there are no small children around. To cover the pins coming out the top I plan on another small piece of teflon to fit over them.
- Tubes / Valves
- 703A tube source?
