diyAudio Sponsor
Old 19th September 2009, 09:02 AM   #1
tomat is offline tomat  Indonesia
Default pre amp output delay circuit?
anyone can give suggestion for simple delay output circuit for tubes preamp?,that could be delayed about for 15 to 20 second.
thanks
Old 19th September 2009, 09:49 AM   #2
aardvarkash10's Avatar
Default schematic would be good
and would help in identifying the best solution
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 19th September 2009, 09:56 AM   #3
ashok's Avatar
Default NE 555 timer
You could use a NE555 timer chip to get you any time delay you want. It could drive a relay connected to the output. Use a small resistor in the output circuit ( series with the output capacitor ) and relay contacts shorting to ground when the coil is not energised. That way the relay contacts will not be in the signal path.
The whole circuit could be powered by the heater supply.
AM
Old 19th September 2009, 10:18 AM   #4
Geek's Avatar
I have a critter that may be of help:
http://www.classicvalve.ca/surplus.html#DELAY
Cheers!
Old 19th September 2009, 10:49 AM   #5
thank you ,and may you have the schematic for this?
Old 19th September 2009, 10:56 AM   #6
Cheers!
thank you ,i will look for this
Old 19th September 2009, 03:36 PM   #7
ashok's Avatar
"...............and may you have the schematic for this? ........."
No I don't but I could put one up for you. However I am going out of town in a few hours time and will be back on Monday. So if you don't see one please post again.
What is the power supply for the heater? Can you put up a circuit diagram of the heater power supply. Transformer rating and rectifier circuit if you use dc for the heater. It could be 6 V or 12 V or something close to it.
AM
help with an ne555 delay circuit jarthel Parts 8 19th October 2006 01:14 AM
Stereo delay circuit? keantoken Everything Else 0 30th August 2006 12:35 AM
Is passive delay circuit possible? MXM Car Audio 7 26th November 2004 09:40 PM
B+ delay circuit joeling39 Tubes / Valves 11 23rd September 2003 11:38 PM
Page generated in 0.08227 seconds (78.18% PHP - 21.82% MySQL) with 10 queries
