| diyAudio Sponsor | ||
I'm planning a phono stage with an outboard PS. I will need a connectors for the B+ power cord. Other than Cinch-Jones and molex, are there better choices?
#2 |
Personally, I think the military style Amphenol olive drab circular connectors to be the best, at a ridiculously high price.
#3 | |
![]() Buy them here (and many other places) http://www.rfparts.com/c-bnc.html |
#4 |
#5 |
#6 |
There may be better choices, but I've used octal sockets, both 8 and 11 pin with matching male connectors with success and no problems. Just remember to ensure that the energized end is the female end, so if the power supply is "turned-on" while disconnected, no dangerous live pins will be exposed.
Triode Electronics Online sells them http://store.triodestore.com/amphenol.html Stuart |
#7 |
3pole, 4pole and 5pole XLRs are available in a range of plug and socket types.
these can take adequate current and voltage for a PSU.
regards Andrew T. |
#8 |
Just my $.02
#1. If the Phono stage has any significant value B+ capacitors on its chassis, the exposed pins of an octal would not be a good idea. #2. Chris A's idea along with Andrew's look to be about the safest and relatively secure. #3. One thing I would consider is avoiding any connector that is the same as something else you have at hand. ie; if you have XLR's in the system avoid them. #4 Be sure to take into account kids pets etc. Personnally I would use something with 4 pins so that you can run the primary (120V) through it so that it "kills" the supply when disconnected. |
#9 | |
...then plug them into microphone ins. PS cables must be unique.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#10 |
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Can anyone ID this type of edge connector? | HankMcSpank | Parts | 2 | 26th May 2008 01:54 PM |
| What type of connector is this? | bubba61389 | Parts | 9 | 24th October 2006 03:10 AM |
| What type of connector for coaxial O/P | theoracle | Digital Source | 2 | 10th February 2005 05:03 PM |
| pcm1704 outboard dac | mermoz | Digital Source | 4 | 7th September 2002 06:05 PM |
| Page generated in 0.08846 seconds (87.59% PHP - 12.41% MySQL) with 10 queries |
