Vacuum State RTP3C - Page 6 - diyAudio
Old 8th July 2011, 08:52 AM   #51
damohpi is offline damohpi  Australia
while I agree with the post just above, IIRC the RIAA, coupling, etc. capacitors Allen used in the RTP-3D and SVP-2 were Kemet SMC series (PPS SMD)
Old 9th July 2011, 12:56 AM   #52
cjcc67 is offline cjcc67  Australia
Interesting they're SMD.
Old 18th July 2011, 06:21 AM   #53
Just thinking about the Power supply for the CC and voltage refs. Is there any point using chokes in addition to the ss regulators?
Old 4th September 2011, 11:04 AM   #54
Currently working on building the RTP3
Vacuum State - High End Hifi Equipment
I have this cct to use as the ccs. I just want to check before I proceed that I connect the -25V to the supply (obviuos) and the 0v connection to 'point c' indicated on the schemtic between the two emmiter resitors of the MAT02?
I have a LOMC so won't be using them but am considering using a 4PDTswitch allowing the 332 ohm to be selected for mm.
2nd question is are two 0,47UF caps in parallel close enough in value to the 1.0 uf caps?
Rhanks for your help
Craig
Old 4th September 2011, 11:16 AM   #55
Originally Posted by Jaap View Post
I have matched 2sk369 for sale. PM me if you want some
Thanks i'll need a pair a bit later.
Old 4th September 2011, 01:24 PM   #56
Kim Bay Smidt's Avatar
Craig
Hi Craig,
Looks like the "old" RTP3c schematic you linked to only were prepared for a single CCS and not a dual CCS as you plan to use.
The two CCS should not be connected to the zero point. Instead they should be connected to the respective emitters of the MAT02. Between the emitters you have one resistor to set the gain.
The second question. Which 1.0uF cap? The one connected to LM329? It's not critical but why not use a single 1.0uF?
The two 1.0uF coupling caps are critical and should be matched (as every other component in the RIAA correction circuit.)
I recommend to order the instruction CD from vacuumstate.com, the money spend will insure that one get the RTP3 build as intended. Second, use what Allen recommended of components and substitute later. Have fun!
Genuine Toshiba 2SJ74s
Old 4th September 2011, 01:39 PM   #57
Thanks Kim.
The gain for MC if i understand correctly is 0R therefore no resistors. This dual ccs is to have half the current 9.5 mA flowing in each side.
The coupling caps. I was thinking of using some russian teflon caps.
I agree about the cd. Unfortunately it is no longer for sale from vacuumstate. perhaps someone has one they are willing to sell?
Craig
Old 4th September 2011, 04:08 PM   #58
Alex M is offline Alex M  Europe
I agree that the components in the shunt part of the correction circuit (between the anodes of the valves) should be chosen to at least 1% and matched between channels to within better than this, but in my opinion the coupling caps after the phone stage (which, incidentally, in the version I used are 0.47 uF) are less critical: with my values the LF corner frequency is around 7 Hz, and 5% deviations for this are unlikely to be audible
Alex
Old 5th September 2011, 10:10 AM   #59
Alex,
Can you please confirm the connection methodology for the ccs and which loops you are measuring the 9.5 mA.
Cheers
Craig
Old 5th September 2011, 10:36 AM   #60
Alex,
Cheers
Craig
Hi Craig,
The circuit I sent you should be inserted between the -25V unregulated supply and the emitter resistors of the input stage (which are absent for the standard LOMC configuration, in which case the CCS is connected directly to the emitters).
You measure the voltage across each of the fixed 1K0 resistors in the CCS in turn and adjust the pots in series with these: when the voltage is 9.5 V across both of the resistors, the current through each should be 9.5 mA and the total through the tail of the input stage 19 mA.
Alex
Any comment on Vacuum State dpa300b?? la1209 Tubes / Valves 52 17th February 2017 07:50 AM
Vacuum State SuperREGS tubesguy Swap Meet 5 1st March 2009 03:05 PM
Vacuum State RTP5. InSides Tubes / Valves 4 15th March 2008 04:40 PM
My version of the Vacuum State FVP5 Shoog Tubes / Valves 67 18th January 2008 04:26 AM
Copyright 1999-2017 diyAudio
