| diyAudio Sponsor | ||
#2 |
Nope. Nice to see LEDs get their due. This is a trick I first saw back in the late '70s, and when used appropriately, it's a great trick. I wonder why this guy didn't bias the output stage with an LED array... There can't be too many LEDs in a project. Nope, can't be too many.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 | |
I've seen that before, but can't recall where that was. |
#4 | |
http://www.pimmlabs.com/
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 | |
#6 | |
#7 |
Both the 6DE7 and 6EW7 have small signal sections with u= 17.5. The 6DR7's small signal section has: u= 68. You can get quite a bit more gain out of that. The linearity also ain't none too bad.
#8 | |
#9 |
Hmmm, dunno about using NE2s as voltage refs. Out of a bag of twenty I find a firing voltage between 60V and 94V.
They are good in a string at the end of a long aerial (almost half a mile) to drain atmospheric potential (lethal). The last one in a string of twenty or so can have a diode and a piezo sounder across it, it makes a cracking indication for an impending storm. Of course they need to be in a strong case. If there is a lightning strike then all the guts will be blown from everything. A diecast ally case will suffer severely (I know) but it will be the shortest path and save most other kit. |
#10 |
| What every Class AB builder needs to be constantly aware of | amplifierguru | Solid State | 218 | 20th May 2005 02:23 PM |
| Page generated in 0.10675 seconds (78.09% PHP - 21.91% MySQL) with 10 queries |
