cheap tubes are just not worth it - diyAudio
Old 15th May 2003, 01:56 AM   #1
karma is offline karma  Canada
karma's Avatar
Thumbs down cheap tubes are just not worth it
i could of got the more pricy one but no i wanted to save a buck
if you look in the pic you can see one of the plates glowing red not good.and the filement looks to a little brighter. yet my old ones work fine. im looking at a bias ajustment right? i only paid
19$ for the set and there matched
Old 15th May 2003, 01:58 AM   #2
karma's Avatar
Default .
Old 15th May 2003, 02:00 AM   #3
karma's Avatar
Default 1
or is it i just never looked at them in the dark hmm
hmm kinda has purple rings to top and bottom cool
Old 15th May 2003, 03:07 AM   #4
Brett's Avatar
Send them back.
Old 15th May 2003, 03:10 AM   #5
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
You mean they have purple rings around when they are on???
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 15th May 2003, 03:12 AM   #6
karma's Avatar
na ill just keep em for testers. im going to pick up the one's i wanted thursday. ill likelly need to bias them
Old 15th May 2003, 03:13 AM   #7
karma's Avatar
ya when there on looks kinda cool
purple haze
Old 15th May 2003, 03:14 AM   #8
Duo's Avatar
If they're glowing with purple when they're on, the the tubes are gassy, which they should not be... Unless these are thyratrons or regulators, which I doubt they are judging by their configuration and the fact that you are biasing them.
Old 15th May 2003, 03:17 AM   #9
karma's Avatar
there 6l6 gb's in push pull but i did replace the rectifier to
i didnt bias them yet
Old 15th May 2003, 03:22 AM   #10
karma's Avatar
ill see if i can get a pic with the purple haze so you can judge it
CHEAP function generator. Worth it? MJL21193 Parts 3 31st December 2007 01:58 PM
Are these tubes worth annything? webercarbmann Tubes / Valves 2 10th November 2006 12:16 PM
Worth to buy - tubes? marijan Tubes / Valves 12 9th June 2005 10:37 PM
Are cheap speakers worth? wxn Multi-Way 3 11th July 2004 12:19 PM
Cheap router, worth it? jdeare Equipment & Tools 6 18th February 2003 01:49 AM
Copyright 1999-2017 diyAudio
