cheap tubes are just not worth it - Page 3 - diyAudio
Old 20th May 2003, 01:51 PM   #21
316a is offline 316a  England
316a's Avatar
Default If we're talking DIY
...why use new production in the first place ? Quality does not seem too good at present . I have seen , and tested quite a few recent Sovtek , Ei and Chinese valves . The Sovteks were 6L6's for a guitar amp . Out of 8 I could only make one matched pair , the test result spread was about 15% so these actually aren't that bad . Chinese valves were NOS 6SN7 from the 1970's , appallingly awful , 30% were 'faulty' on the tester for leakage , 50% had poor sectional balance (>20% difference) , leaving 20 almost good ones out of a hundred . Ei were silver plate ECC83 . I could make the gm reading change just by tapping the glass gently . The crimps on the anodes looked suspiciously loose . Back to the supplier they went . I can only recommend if using 6L6 family valves to seek NOS 6BG6G . 6BG6G are just a 6L6 with a topcap . Otherwise 807 , 5B/255M can be substituted for 6L6 with a socket change . 6BG6 , 807 , 5B/255M are all very cheap and available
316a
Old 20th May 2003, 09:22 PM   #22
mig-ru is offline mig-ru  Russian Federation
The blue/purple glow like that is fine, that is caused by stray electrons, that miss the plate, hitting the glass. This happens with my triode operated 6197's, looks pretty cool. The bad blue glow is when the whole tube glows blue, that means it has gas in it.
Old 20th May 2003, 09:43 PM   #23
diyAudio Senior Member
fdegrove's Avatar
Sure these were made by EI, sounds more like those French Post Office tubes to me...
I think ot is a chromium plating of the anodes, not really my kind of thing...the sound awkward.
Frank
CHEAP function generator. Worth it? MJL21193 Parts 3 31st December 2007 12:58 PM
Are these tubes worth annything? webercarbmann Tubes / Valves 2 10th November 2006 11:16 AM
Worth to buy - tubes? marijan Tubes / Valves 12 9th June 2005 09:37 PM
Are cheap speakers worth? wxn Multi-Way 3 11th July 2004 11:19 AM
Cheap router, worth it? jdeare Equipment & Tools 6 18th February 2003 12:49 AM
Copyright 1999-2017 diyAudio
