12V AC to 6.3v DC simple supply for idiots
Old 13th September 2009, 09:47 PM   #11
coldcathode is offline coldcathode  United States
coldcathode's Avatar
One "DOWN" and dirty, completely idiot proof and relatively cheap way to go would be look on Epay for a 12.6V "Laptop" powersupply. Wire the heaters of the PP pairs in Series and the 2 CG7's in series. Parallel the 3 pairs and put an input jack on the chassis.
Here's one
You can put the supply far enough away from the chassis so there is no noise. That one in the link is 4Amps plenty of power for the filaments.
Old 14th September 2009, 01:53 AM   #12
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Default why DC Drew?
are you having issues with noise? I just completed my EL36/6CM5 p-p last night (well, almost completed... one channel still needs to be tweeked...)
It uses a 24VAC transformer feeding the output tubes (4 x 6.3 @ 1.2A) and the voltage amps (6J7) + phase splitters (6J5) (4 x 6.3 @ 0.3A) as two series chains.
At the moment it is running bare - I will probably virtual centre-tap it later on, but so far no noise issues and it has made dealing with the 1.2A heater current in the EL36 a non-issue.
JMTCW...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 14th September 2009, 02:06 AM   #13
DrewP is offline DrewP
JMTCW...
Not yet, still at the getting bits together stage. Had been advised not to AC heat the 6CG7's. Happy to go with the original AC heated design and take my chances with a retrofit later on if needed...
You've talked me into it, will series the heaters and run off the 12v AC supply first up and we'll see how things go...
12V AC to 6.3v DC simple supply for idiotsHide this!Advertise here!
idiots guide to impedance + spdif measurement woodturner-fran Digital Line Level 7 20th October 2008 06:04 PM
Simple DC Heater Supply d1camero Tubes / Valves 9 19th October 2007 10:33 PM
Idiots question on resistors. Wella Tubes / Valves 3 8th July 2003 11:49 AM
