| diyAudio Sponsor | ||
Here is my interpretation of a recent idea for SE characteristics in a PP amplifier. It's more of a SE driving PP idea but the combination of high-gm and plate feedback should allow the output stage to follow the SE driver's harmonic signature.
The driver is a sort of inverting-current-mirror which is expected to drive it's side of the push-pull output stage in anti-pentode style, where the pentode load is the plate feedback. R104, R105, R107, R108 form a bridge that feeds the inverting input of IC1 such that a signal voltage is developed on the grid of V102 that causes an opposing dynamic current in V102, opposite the signal current in V101. Any asymmetry in the transfer function of V101 will not be cancelled, as the opposing current in V102 will cause a signal to be combined in the OPT in inverse polrity. I.e. when inverted twice, once in the current mirror and again in the OPT, the asymmetry is additive as is the signal. So it doesn't mimic the asymmetric gm of a SE output stage driving a loudspeaker, but neither should it convert much even harmonic distortion into odd harmonic distortion given the balanced plate feedback to the current mode SE + current mirror phase inverter. The idea is to have a non-cancelling driver stage followed by a transparent power stage. Constant balanced bias voltage for the output tubes is provided by the low pass filtered servo loop R106, C103 resulting in a constant equal current through L1, L2, and bias adjusters R113 and R114. The idea is to set the bias voltage for equal current at idle, after which adjustment would only be needed for aging or replacement of the output tubes. |
#2 |
Interesting anti-triode splitter using the Op. Amp. Keeps V101 and V102 AC currents complementary and DC currents matched. The shunt regulators V103 and V104 keep screen currents out of the cathodes. The bias servoing looks like it keeps V101 and V102 DC currents matched, but it is sensitive to DC coming in the input as to what bias it balances. Are L1 and L2 coupled? I have no idea how linear the 4CX250 tubes are in class AB.
Don
Ohms Law V = I R Last edited by smoking-amp; 13th September 2009 at 11:06 PM. |
#3 | |
L1 and L2 could be coupled, but the curent plan is to use the Valab chokes I have which are separate. I'm not sure what the effect would be to voltage-couple the 2 sides. Which leads into the linearity of 4CX250s. The composite gm is about 10,000 throughout the conduction overlap between the 2 sides up to about 20,000 at peak current for this example loadline. This by itself could be a source of third harmonic distortion, but I expect the local feedback to linearize the voltage swing. The 1/gm contribution to effective Rp is therefore 50-100 ohms over the full signal swing with the feedback scheme I have. The load is 2K (8K plate-plate). Maybe there's a 4cx250 spice model... |
#4 |
Why not use DC-coupling of the inverse feedback resistor if you are worried about subsonics? Then you can let the currents add: 10mA from the feedback-path and and 10mA from the choke-path. 15W over the feedback resistor though
Brgds Lars |
#5 |
Michael,
Thinking about an anti-triode splitter stage driving a class AB output stage, I believe that one wants a triode driving an anti-triode and an anti-triode driving a triode to avoid the usual distortion cancellation between stages. (I realize that your present setup is oriented toward transparancy in the output stage, this variant would be the hypothetical approach if one wanted to let the outputs distort naturally, well, at least the triode sides) Looking at your ampl., using the Op. Amp. anti-controller scheme, one would just use cathode sense resistors for all four tubes and scale the resistors in the ratio of currents expected. Then add an Op Amp controller for each P-P side's forward link from driver tube to output tube grid. So three Op Amps total with the two added ones. V101 remains the master triode, V105 becomes an anti-triode slave to it. V102 remains anti-triode to V101, and V106 becomes a triode slave to it. Problem with this scheme though is that the driver tube plates aren't even being used, so are almost do nothings. Well, some more work needed on the idea. Of course this all pre-supposes class A operation everywhere, so some clamps would be required to stop saturation of the Op. Amps when an output tube cuts off. At least one feedback link makes sense so far. The V106 plate fed back to the V101 screen would be connecting triode to triode, preserving SE distortia spectra, and having the correct polarity. I am still trying to convince myself that the opposite V105 plate to V102 screen feedback would make sense distortion-wise. Alternatively, V105 plate to V101 plate may make sense since it references the master triode inversely. If so, then the dual plate to plate feedbacks in your present design would fit right in. Anyway, just some ideas to chew on. Don
Ohms Law V = I R Last edited by smoking-amp; 15th September 2009 at 05:19 PM. |
#6 |
Been looking at the anti-triode splitter/driver followed by class AB outputs scheme some more. Firstly, the anti-triode driver to triode output tube link doesn't need any Op. Amp. anti-controller in between. Just the usual plate to grid drive is fine there.
The triode driver to anti-triode output tube link does need something special, but just monitoring cathode currents and an Op. Amp. control is not really hacking that. The problem being that the output load impedance may not be linear or constant with frequency. So this control would need modifying to use voltages instead of currents. But then the voltage sense monitors the effects of both output tubes, not just the one to be anti'd. So I don't see a way to do this yet without big added complexity. Then, for the crossed output plates back to driver screen feedbacks idea, it looks like both links are OK, but the result is to preserve only the driver distortion spectra (providing enough gain is in the loops, gyrator loads on the drivers). So the output of the whole thing looks like SE driver distortion, and doesn't much care whether the one output tube is anti-trioded or not. With weak loop gain though (resistor loads on drivers), the output stage distortion also chimes in some, and with no anti-triode there, will mean some of the usual odd order distortions. A problem here, with high loop gains even (unloaded driver plates), is that the driver stage distortion also falls down toward ir-reducible constant current Mu distortion levels. This can be 50 or 60 dB (or even more) down for some tubes, and may not be hearable anymore. So seems that the ideal solution would be to get an anti-triode working on one side of the P-P output stage, and then adjust the driver resistor loads until the sought after SE effect is sufficient. This would then be a blend of the SE effect from both the driver stage and the output stage. Don
Ohms Law V = I R Last edited by smoking-amp; 18th September 2009 at 08:11 PM. |
#7 | |
I am not sure I follow your vocabulary here, but if you are refering to Michaels schematic having unloaded plates, this is not true. With the inverse feedback applied to the output tubes it will load the driver with just few kOhm (or Rnfb/(Rl*Gm+1)).
Brgds Lars |
#8 |
Sorry, I was referring to the hypothetical plate to driver screen feedbacks approach I mentioned earlier. Yes, agree, Michael's plate to plate feedbacks will keep the driver loaded. Seems that either approach tends to null out the output stage distortion. Just looking for some possible handle to get the output stage to look SE like also.
Don
Ohms Law V = I R Last edited by smoking-amp; 18th September 2009 at 10:58 PM. |
#9 |
R.I.P.
Why Oh why, do you have to put an op-amp in the signal path?
Sure they solve many technical problems very easily, but can't you hear what they do to the music? Regards, Allen (Vacuum State) |
#10 |
I did that in my Alligator project, but the opamp and MOSFET that were used as a current source were totally out of a NFB loop. The phase splitter was alone, driving both 2-tube SE amp with own feedback by voltage, and an opamp+MOSFET CCS in another shoulder. It sounded very SEish.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| Current Mirror: The V-mirror | rtarbell | Solid State | 1 | 19th November 2008 02:27 PM |
| no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? | maxpou | Solid State | 31 | 17th June 2008 04:31 PM |
| A special current mirror | pjacobi | Solid State | 13 | 16th June 2008 04:16 PM |
| Current mirror | abzug | Solid State | 7 | 1st January 2008 07:03 PM |
| Page generated in 0.12801 seconds (91.26% PHP - 8.74% MySQL) with 11 queries |
