diyAudio Sponsor
Old 12th September 2009, 12:43 AM   #1
coldcathode's Avatar
Default 829B/3E29 "Triode" Push Pull Paralleled Sections
With a big tip O' the hat to Pete Millett I have jumped feet first into designing a rather simple Push Pull amp using the 829B/3E39 transmitting tube.
First, A little background as to why such a "bizarre" tube choice for a relative "beginner" to tube audio.
My first experience with Tube Audio came purely by accident after having found an old Grunow "Console" Radio in a junk pile. I liked the look of it and wanted to make it work. I found the schematic online and played with it for a while. The "sound" seemed so much better even in Mono than anything I had heard that I became intrigued with tubes.
I started picking up tubes etc at estate sales and built a couple of SE amp using proven designs off the net and "junk box" parts.
I came across an old US Army Signal Corps transmitter with (2) 829B's and a beefy power tranny in another trashpile. Having grown up watching M.A.S.H. it was so much like "Radar's" setup I had to take it home.
fast forward about 2 years and I have these 829B's along with some nice Shielded sockets and I came across Pete Millett's 829B SE and really liked that idea. Since SE Iron is relatively expensive and hard to find in "trashpiles" I held off building anything till I could really design something PP.
So I now have my hands on a set of decent PP output trannies capable of the idle current that I want to use with around 7800R P to P.
Time to start "designing".
The overall concept is plain vanilla since the choice of output tube is interesting enough. One half 6SN7 input/gain stage into the second half "split load" phase splitter. Then a 6CG7/6FQ7 will drive the 829B grids.
I am going with P to P of 7800 ohms into 8.
A B+ of 300V, Cathode Bias of about -30V for ~80mA per tube idle current.
Any comments as to whether or not I am sane?
Old 12th September 2009, 01:14 AM   #2
SY's Avatar
Depends. How many 829s do you have? If you want to run triode pp, you'll need 4 of them for a stereo amp. Pentode, you only need 2. Hint: screens are tied together and bypassed to cathode internally....
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th September 2009, 01:24 AM   #3
I forgot to mention that along the way I have amassed a collection of (7) 829B's all RCA from about the same years in production.
I happened to pick up a lot of boxes of "ham radio" stuff from Flea Markets and Estate Sales. Since I really have no tester to test these I can verify that the filaments are good, I figured it's a decent chance I will have (4) good ones out of 7.
Pentode would give me much more power but looking at the "triode" curves it has pretty good linearity and I will try the "triode sound" for now.
Snip out the G2 connection to the plate and supply it with 200V or so in the future is no problem if I want to go pentode.
Old 15th September 2009, 12:11 AM   #4
A "first rough draft of one channel"
I am sure I made some mistakes. Let me know what you find.
Suggestions as to an interesting input tube? I have some Globe 27's "meshies" might be an interesting look?
Old 15th September 2009, 12:41 AM   #5
rman is offline rman  Canada
rman's Avatar
Hi.
Just a thought. If you bias that firs stage, the one you have no load or cathode resistor shown for, so that you have about one third B+ on the plate, you could direct couple and forget about the bias elements and grid resistor for the phase splitter.
Cheers.
Rolf.
Old 15th September 2009, 02:06 AM   #6
aardvarkash10's Avatar
Default one tube too many?
Why not use the 6J5 as input triode to the 'sn7 as a LTP splitter? Should give all the gain you need and reduce the tube count by one per channel.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 15th September 2009, 12:45 PM   #7
I'm not a big fan of LTP.
I should also have mentioned the "Goals" of this amp.
1: Use the 829B along with any other "funky" tubes (going for a "steampunk" theme. Brass, Black Wrinkle finish, Antique look)
2: About 15 watts with 1% distortion or so.
3: Be as weird looking as possible
Old 15th September 2009, 08:32 PM   #8
Originally Posted by rman View Post
Hi.
Cheers.
Rolf.
Rolf,
Something like this 2nd draft?
Old 15th September 2009, 08:43 PM   #9
Now a Powersupply is needed.
This this is starting to become ridiculously over complex. Having lots of funky tubes etc. So might as well continue along that theme.
I am looking at 2 power transformers, one for the 829B's w/ Parallel 5U4GBs a choke etc.
The other for the input, splitter and driver stage.
In keeping with the "too many tubes" theme I am thinking about a VR tube regulated supply.
Heres the question: (2) 0D3's in series gets me the 300V. Can I then add an 0C3 in series with those and the 6.8mA load of the 27's to get my 405V?
If so how would you go about it?
Old 15th September 2009, 08:54 PM   #10
At this point I am looking at a total of about 16 Tubes! LOL for a measly 15WPC stereo!
The power company is going to LOVE me!
The heater filaments alone are dissipating 2 1/2 times the power output!
As crazy as all this seems, I am kind of liking the idea? Certainly would make an interesting "conversation piece", not very efficient but worth a shot.
"Killer" Screen Driven Push-Pull Amp Initial Queries wrenchone Tubes / Valves 41 3rd August 2010 03:24 AM
Chip amps used in "push pull" ChrisA Chip Amps 22 2nd July 2009 09:18 PM
grid impedence of paralleled tubes in push pull nhuwar Tubes / Valves 2 14th January 2007 12:37 AM
Kofi Annan in: "Push and Pull with Me" Kofi Annan Tubes / Valves 340 6th November 2006 03:18 AM
829B/3E29 datasheet triodemode permagne Tubes / Valves 3 19th December 2004 12:01 PM
Page generated in 0.11299 seconds (78.56% PHP - 21.44% MySQL) with 11 queries
